RCF MB15H401 15" Midbass Speaker
Brand:|Model: MB15H401|Part # 294-872
The MB15H401 is ideal for use in applications requiring good power handling, very high efficiency, and perfect linearity.
ORDER TODAY
Ships in 7-10 Business Days
List Price$537.00
You Save29%
$381.00
Part # 294-872
  • Very efficient low-distortion midbass driver
  • 4" diameter inside/outside aluminum voice coil on fiberglass former
  • 1,400 watt continuous program power handling
  • Distortion-reducing aluminum demodulation ring
  • Dual spider design with silicon based damping control
  • Triple roll constant geometry surround and fiber-loaded exponential cone
RCF's MB15H401 is a midbass/woofer with linear frequency response and very high efficiency. To achieve this performance, the magnetic structure uses a demodulation ring and a fiber-loaded exponential cone assembly, along with a high excursion triple-roll, constant geometry surround. The fiberglass former, inside/outside, aluminum voice coil provides excellent thermal and mechanical durability, and the aluminum demodulation ring guarantees fast time response and low distortion. The MB15H401 is ideal for use in applications requiring good power handling, very high efficiency, and perfect linearity. It is the ideal 15" woofer for midbass applications in compact 2-way systems, and its smooth response facilitates crossover designs.
  • Nominal Diameter15"
  • Power Handling (RMS)700 Watts
  • Power Handling (max)1400 Watts
  • Impedance8 ohms
  • Frequency Response40 to 2,000 Hz
  • Sensitivity100 dB 2.83V/1m
  • Voice Coil Diameter4"
  • Resonant Frequency (Fs)44 Hz
  • DC Resistance (Re)5.4 ohms
  • Voice Coil Inductance (Le)1.9 mH
  • Mechanical Q (Qms)4.8
  • Electromagnetic Q (Qes)0.32
  • Total Q (Qts)0.3
  • Compliance Equivalent Volume (Vas)4.27 ft.³
  • BL Product (BL)22.1 Tm
  • Diaphragm Mass Inc. Airload (Mms)107g
  • Maximum Linear Excursion (Xmax)7.5 mm
  • Surface Area of Cone (Sd)910 cm²
  • Cone MaterialPaper / Carbon Fiber
  • Surround MaterialCloth
  • Voice Coil FormerFiberglass
  • Overall Outside Diameter15.5"
  • Baffle Cutout Diameter13.9"
  • Depth6.2"
  • # Mounting Holes8
  • Sealed Volume0.67 ft.³
  • Sealed F3117 Hz
  • Vented Volume1.33 ft.³
  • Vented F374 Hz
  • BrandRCF USA
  • ModelMB15H401
  • Part Number294-872
  • UPC844632090165
  • Weight29.3000 lbs.
View similar products to the RCF MB15H401 15" Midbass Speaker
Part # 294-872
