RCF MB12N351 12" Neodymium Midbass Speaker
Brand:|Model: MB12N351|Part # 294-848
The RCF MB12N351 delivers excellent frequency response linearity with low distortion.
Ships in 7-10 Business Days
List Price$558.00
You Save29%
Part # 294-848
  • Very efficient low-distortion midbass driver
  • Strong, lightweight neodymium magnetic structure
  • 3.5" diameter inside/outside copper voice coil on fiberglass former
  • 1,300 watt continuous program power handling
  • Single spider design with silicon based damping control
  • M-roll surround, light moving mass, and exponential cone geometry
  • Dual forced air ventilation for minimum power compression
The RCF MB12N351 delivers excellent frequency response linearity with low distortion. A very strong neodymium magnetic structure guarantees great dynamics and precision reproduction, while a new and unique 3.5" voice coil design provides high power handling, especially in comparison to a more common 3" voice coil. The unique dual forced air venting system promotes efficient voice coil ventilation to minimize power compression and maximize power handling. The MB12N351 is ideal for use in applications that require very high efficiency and linearity. It is especially recommended for concert-level multi-way systems.
  • Nominal Diameter12"
  • Power Handling (RMS)650 Watts
  • Power Handling (max)1300 Watts
  • Impedance8 ohms
  • Frequency Response45 to 3,000 Hz
  • Sensitivity99 dB 2.83V/1m
  • Voice Coil Diameter4"
  • Resonant Frequency (Fs)55 Hz
  • DC Resistance (Re)5.6 ohms
  • Voice Coil Inductance (Le)1.65 mH
  • Mechanical Q (Qms)4.5
  • Electromagnetic Q (Qes)0.21
  • Total Q (Qts)0.2
  • Compliance Equivalent Volume (Vas)2.15 ft.³
  • BL Product (BL)22.5 Tm
  • Diaphragm Mass Inc. Airload (Mms)54g
  • Maximum Linear Excursion (Xmax)5.5 mm
  • Surface Area of Cone (Sd)530 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Voice Coil FormerFiberglass
  • Magnet MaterialNeodymium
  • Overall Outside Diameter12.6"
  • Baffle Cutout Diameter11.5"
  • Depth5.4"
  • # Mounting Holes8
  • Sealed Volume0.14 ft.³
  • Sealed F3214 Hz
  • Vented Volume0.31 ft.³
  • Vented F3140 Hz
  • BrandRCF USA
  • ModelMB12N351
  • Part Number294-848
  • UPC844632090042
  • Weight11.4 lbs.
RCF L15S801 15" Woofer Speaker
Part #  294-864
RCF L15/554K 15" Woofer Speaker
Part #  294-866
View similar products to the RCF MB12N351 12" Neodymium Midbass Speaker
