RCF MB12G301 12" Midbass Speaker
Brand:|Model: MB12G301|Part # 294-842
Very high sensitivity, excellent linearity, and low distortion. The MB12G301's voice coil construction, suspension, and cone materials are designed to survive easily at 400 watts RMS power.
List Price$364.00
You Save29%
$258.00
Part # 294-842
  • Very efficient midbass driver
  • 3" diameter inside/outside aluminum voice coil on fiberglass former
  • 800 watt continuous program power handling
  • High sensitivity, low distortion
  • Great for 2-way systems thanks to smooth, extended response
  • M-roll surround, light moving mass, and exponential cone geometry
Very high sensitivity, excellent linearity, and low distortion. The MB12G301's voice coil construction, suspension, and cone materials are designed to survive easily at 400 watts RMS power. The aluminum voice coil guarantees a very high efficiency in conjunction with a proper Q factor for good bass response.
  • Nominal Diameter12"
  • Power Handling (RMS)400 Watts
  • Power Handling (max)800 Watts
  • Impedance8 ohms
  • Frequency Response50 to 3,000 Hz
  • Sensitivity98 dB 2.83V/1m
  • Voice Coil Diameter3"
  • Resonant Frequency (Fs)53 Hz
  • DC Resistance (Re)5.4 ohms
  • Voice Coil Inductance (Le)0.7 mH
  • Mechanical Q (Qms)4.7
  • Electromagnetic Q (Qes)0.28
  • Total Q (Qts)0.27
  • Compliance Equivalent Volume (Vas)2.54 ft.³
  • BL Product (BL)17 Tm
  • Diaphragm Mass Inc. Airload (Mms)48g
  • Maximum Linear Excursion (Xmax)5.5 mm
  • Surface Area of Cone (Sd)530 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Magnet MaterialFerrite
  • Overall Outside Diameter12.6"
  • Baffle Cutout Diameter11.5"
  • Depth5.4"
  • # Mounting Holes8
  • Sealed Volume0.26 ft.³
  • Sealed F3168 Hz
  • Vented Volume0.59 ft.³
  • Vented F3107 Hz
  • BrandRCF USA
  • ModelMB12G301
  • Part Number294-842
  • UPC844632090028
  • Weight18 lbs.
View similar products to the RCF MB12G301 12" Midbass Speaker
Part # 294-842
