294-895_ALT_0
RCF LF21N451 21" Neodymium Woofer Speaker
Brand:|Model: LF21N451|Part # 294-895
RCF's LF21N451 is specially designed to provide powerful and accurate sub-bass frequencies with low distortion and minimal power compression.
ORDER TODAY
Ships in 7-10 Business Days
List Price$1,075.00
You Save29%
$763.00
Part # 294-895
  • Designed for concert systems
  • 4.5" diameter inside/outside copper voice coil
  • 3,000 watt continuous program power handling
  • Dual forced-air ventilation for minimum power compression
  • Double spider incorporates silicon damping
  • 13.2 mm Xmax, 58 mm peak-to-peak Xmech
  • BL of 34.5 T/m provides faster and more accurate low frequency response
RCF's LF21N451 is specially designed to provide powerful and accurate sub-bass frequencies with low distortion and minimal power compression. Its voice coil length was engineered to improve excursion and linearity at very low frequencies. The LF21N451 uses a unique RCF-developed carbon fiber/nylon/cellulose composite pulp that reinforces and improves the cone structure's rigidity. This new cone structure and the large triple roll surround/double silicon spider system ensure excellent control and make the cone resistant to deformation caused by very large displacements and pressure created by the transducer’s high excursion behavior. A fully optimized T-pole design generates the minimum amount of flux modulation in the magnetic gap. The LF21N451 excels in applications where light weight and high power handling are required.
  • Nominal Diameter21"
  • Power Handling (RMS)1,500 Watts
  • Power Handling (max)3000 Watts
  • Impedance8 ohms
  • Frequency Response30 to 1,000 Hz
  • Sensitivity98.5 dB 2.83V/1m
  • Voice Coil Diameter4.5"
  • Resonant Frequency (Fs)30 Hz
  • DC Resistance (Re)5.6 ohms
  • Voice Coil Inductance (Le)3 mH
  • Mechanical Q (Qms)6.1
  • Electromagnetic Q (Qes)0.27
  • Total Q (Qts)0.26
  • Compliance Equivalent Volume (Vas)13.24 ft.³
  • BL Product (BL)34.5 Tm
  • Diaphragm Mass Inc. Airload (Mms)315g
  • Maximum Linear Excursion (Xmax)13.2 mm
  • Surface Area of Cone (Sd)1730 cm²
  • Cone MaterialPaper / Carbon Fiber
  • Surround MaterialCloth
  • Magnet MaterialFerrite
  • Overall Outside Diameter21.5"
  • Baffle Cutout Diameter20.1"
  • Depth9.5"
  • Bolt Circle Diameter20.7"
  • # Mounting Holes8
  • Sealed Volume1.25 ft.³
  • Sealed F3102 Hz
  • Vented Volume2.82 ft.³
  • Vented F366 Hz
  • BrandRCF USA
  • ModelLF21N451
  • Part Number294-895
  • UPC844632090295
    (1 Reviews)
  • Weight31.05 lbs.
View similar products to the RCF LF21N451 21" Neodymium Woofer Speaker
