RCF LF18G401 18" Woofer Speaker
Brand:|Model: LF18G401|Part # 294-888
RCF's LF18G401 is an 18" woofer with linear frequency response characteristics and very high power handling.
ORDER TODAY
Ships in 7-10 Business Days
List Price$645.00
You Save29%
$457.00
Part # 294-888
  • Remarkable linearity in its application range
  • 4" diameter inside/outside copper voice coil on fiberglass former
  • 1,800 watt continuous program power handling
  • 8.5 mm linear excursion, 50 mm peak to peak
  • Triple-roll surround and corrugated straight cone geometry
  • Ideal for high quality professional bass reflex and bass-horn systems
RCF's LF18G401 is an 18" woofer with linear frequency response characteristics and very high power handling. It uses a fiber-loaded cone assembly along with a high excursion triple roll, constant geometry surround. This combination provides remarkable strength and 2" peak to peak maximum excursion before damage. The LF18G401 is ideal for use in applications where incredible power handling, long excursion, and perfect control are required. The robust mechanical design and optimized weight of the device make it desirable for use in fixed installation or portable professional loudspeaker systems.
  • Nominal Diameter18"
  • Power Handling (RMS)900 Watts
  • Power Handling (max)1800 Watts
  • Impedance8 ohms
  • Frequency Response30 to 1,000 Hz
  • Sensitivity98 dB 2.83V/1m
  • Voice Coil Diameter4"
  • Resonant Frequency (Fs)33 Hz
  • DC Resistance (Re)4.8 ohms
  • Voice Coil Inductance (Le)2.4 mH
  • Mechanical Q (Qms)7.6
  • Electromagnetic Q (Qes)0.3
  • Total Q (Qts)0.29
  • Compliance Equivalent Volume (Vas)9.46 ft.³
  • BL Product (BL)24.6 Tm
  • Diaphragm Mass Inc. Airload (Mms)182g
  • Maximum Linear Excursion (Xmax)8.5 mm
  • Surface Area of Cone (Sd)1220 cm²
  • Cone MaterialPaper / Carbon Fiber
  • Surround MaterialCloth
  • Voice Coil FormerFiberglass
  • Magnet MaterialFerrite
  • Overall Outside Diameter18.3"
  • Baffle Cutout Diameter16.7"
  • Depth8.1"
  • # Mounting Holes8
  • Sealed Volume1.36 ft.³
  • Sealed F391 Hz
  • Vented Volume2.7 ft.³
  • Vented F358 Hz
  • BrandRCF USA
  • ModelLF18G401
  • Part Number294-888
  • UPC844632090240
  • Weight30.4 lbs.
RCF L15/554K 15" Woofer Speaker
Part #  294-866
RCF L15S801 15" Woofer Speaker
Part #  294-864
View similar products to the RCF LF18G401 18" Woofer Speaker
Part # 294-888
