RCF LF18G400 18" Woofer Speaker
Brand:|Model: LF18G400|Part # 294-890
RCF's LF18G400 is an 18" woofer with linear frequency response characteristics and very high power handling.
Ships in 7-10 Business Days
List Price$796.00
You Save29%
Part # 294-890
  • Remarkable linearity and power handling
  • 4" diameter inside/outside copper voice coil on fiberglass former
  • 2,000 watt continuous program power handling
  • 9 mm linear excursion, 50 mm peak to peak
  • Unique T-pole, curved on top, and 14 mm top plate for minimum power compression
  • Triple-roll surround and fiber-loaded corrugated straight cone geometry
  • Dual spider design with silicon-based damping control
RCF's LF18G400 is an 18" woofer with linear frequency response characteristics and very high power handling. It uses a fiber-loaded cone assembly along with a high excursion triple roll, constant geometry surround. This combination provides remarkable strength and 2" peak to peak maximum excursion before damage. A uniquely shaped T-pole in the motor circuit and 14 mm thick top plate contribute to the driver's superior power handling and low compression. The LF18G400 is ideal for use in applications where incredible power handling, long excursion, and perfect control are required. The robust mechanical design and optimized weight of the device make it desirable for use in fixed installations or portable professional loudspeaker systems.
  • Nominal Diameter18"
  • Power Handling (RMS)1,000 Watts
  • Power Handling (max)2000 Watts
  • Impedance8 ohms
  • Frequency Response25 to 1,000 Hz
  • Sensitivity97.5 dB 2.83V/1m
  • Voice Coil Diameter4"
  • Resonant Frequency (Fs)28 Hz
  • DC Resistance (Re)5.1 ohms
  • Voice Coil Inductance (Le)2.5 mH
  • Mechanical Q (Qms)4.6
  • Electromagnetic Q (Qes)0.29
  • Total Q (Qts)0.27
  • Compliance Equivalent Volume (Vas)12.71 ft.³
  • BL Product (BL)24.2 Tm
  • Diaphragm Mass Inc. Airload (Mms)190g
  • Maximum Linear Excursion (Xmax)9 mm
  • Surface Area of Cone (Sd)1220 cm²
  • Cone MaterialPaper / Carbon Fiber
  • Surround MaterialCloth
  • Voice Coil FormerFiberglass
  • Magnet MaterialFerrite
  • Overall Outside Diameter18.3"
  • Baffle Cutout Diameter16.7"
  • Depth8.3"
  • # Mounting Holes8
  • Sealed Volume1.31 ft.³
  • Sealed F389 Hz
  • Vented Volume2.97 ft.³
  • Vented F357 Hz
  • BrandRCF USA
  • ModelLF18G400
  • Part Number294-890
  • UPC844632090257
  • Weight33.7 lbs.
RCF L15S801 15" Woofer Speaker
Part #  294-864
RCF L15/554K 15" Woofer Speaker
Part #  294-866
View similar products to the RCF LF18G400 18" Woofer Speaker
Part # 294-890
