RCF LF15N401 15" Neodymium Woofer Speaker
Brand:|Model: LF15N401|Part # 294-878
RCF's LF15N401 boasts incredibly linear frequency response characteristics, the highest power handling of any comparable 15" neodymium transducer, and the lowest power compression.
List Price$623.00
You Save29%
$442.00
Part # 294-878
  • Highest efficiency/lowest power compression in its class
  • Strong, lightweight neodymium magnetic structure
  • 4" diameter inside/outside copper voice coil on fiberglass former
  • 1,800 watt continuous program power handling
  • Double spider design with silicon based damping control
  • Triple roll surround and corrugated straight cone geometry
  • Dual forced air ventilation and 15 mm top plate for minimum power compression
RCF's LF15N401 boasts incredibly linear frequency response characteristics, the highest power handling of any comparable 15" neodymium transducer, and the lowest power compression. The LF15N401 uses a fiber-loaded cone assembly along with a high excursion triple roll, constant geometry surround. This combination provides remarkable strength and a peak-to-peak maximum excursion (Xmech) of 2". A unique dual forced-air venting system guarantees efficient voice coil ventilation for minimum power compression and higher power handling. The LF15N401 is ideal for use in applications where incredible power handling, long excursion, and light weight are required. Specially designed for touring, this driver is perfect for professional vented and bass horn systems, and its low frequency extension and control also make it ideal for use in critical listening applications such as studio monitor subwoofer systems.
  • Nominal Diameter15"
  • Power Handling (RMS)900 Watts
  • Power Handling (max)1800 Watts
  • Impedance8 ohms
  • Frequency Response35 to 1,500 Hz
  • Sensitivity97 dB 2.83V/1m
  • Voice Coil Diameter4"
  • Resonant Frequency (Fs)34 Hz
  • DC Resistance (Re)5.1 ohms
  • Voice Coil Inductance (Le)2.5 mH
  • Mechanical Q (Qms)5.8
  • Electromagnetic Q (Qes)0.23
  • Total Q (Qts)0.22
  • Compliance Equivalent Volume (Vas)5.65 ft.³
  • BL Product (BL)27.8 Tm
  • Diaphragm Mass Inc. Airload (Mms)158g
  • Maximum Linear Excursion (Xmax)8.8 mm
  • Surface Area of Cone (Sd)910 cm²
  • Cone MaterialPaper / Carbon Fiber
  • Surround MaterialCloth
  • Voice Coil FormerFiberglass
  • Magnet MaterialFerrite
  • Overall Outside Diameter15.5"
  • Baffle Cutout Diameter13.9"
  • Depth6.2"
  • # Mounting Holes8
  • Sealed Volume0.45 ft.³
  • Sealed F3123 Hz
  • Vented Volume0.84 ft.³
  • Vented F380 Hz
  • BrandRCF USA
  • ModelLF15N401
  • Part Number294-878
  • UPC844632090196
  • Weight22.4 lbs.
RCF L15S801 15" Woofer Speaker
Part #  294-864
RCF L15/554K 15" Woofer Speaker
Part #  294-866
Pyle PBW10S 10" Midbass
Part #  292-2528
View similar products to the RCF LF15N401 15" Neodymium Woofer Speaker
are these compatible for replacement of Mackie S-500 woofers  ?
Asked by: justin case
Unfortunately we do not have a cross reference available for this type of thing. Please contact our tech support for more help with this question, tech@parts-express.com or 800-338-0531 x1.
Date published: 2014-08-25
  • 2016-02-09T07:05CST
  • loc_en_US, sid_294-878, PRD, sort_recentQuestionsFirst
