RCF LF15G401 15" Woofer Speaker
Brand:|Model: LF15G401|Part # 294-874
The RCF LF15G401 is a woofer with linear frequency response and very high power handling, achieved by using a fiber-loaded exponential cone assembly and a high excursion triple-roll, constant geometry surround.
ORDER TODAY
Ships in 7-10 Business Days
List Price$537.00
You Save29%
$381.00
Part # 294-874
  • High power, linear response 15" woofer
  • 4" diameter inside/outside copper voice coil on fiberglass former
  • 1,600 watt continuous program power handling
  • Dual spider design with silicon based damping control
  • Triple roll constant geometry surround and fiber-loaded, straight cone
  • 2" peak-to-peak (Xmech) excursion
The RCF LF15G401 is a woofer with linear frequency response and very high power handling, achieved by using a fiber-loaded exponential cone assembly and a high excursion triple-roll, constant geometry surround. Its fiberglass former, inside/outside, copper voice coil provides excellent thermal and mechanical durability. The LF15G401 is ideal for use in applications requiring extreme power handling, long excursion, and perfect control. Very good for 3-way, extended low frequency applications, including professional vented and bass horn systems.
  • Nominal Diameter15"
  • Power Handling (RMS)800 Watts
  • Power Handling (max)1600 Watts
  • Impedance8 ohms
  • Frequency Response30 to 1,500 Hz
  • Sensitivity97 dB 2.83V/1m
  • Voice Coil Diameter4"
  • Resonant Frequency (Fs)36 Hz
  • DC Resistance (Re)4.8 ohms
  • Voice Coil Inductance (Le)2.5 mH
  • Mechanical Q (Qms)6.2
  • Electromagnetic Q (Qes)0.27
  • Total Q (Qts)0.26
  • Compliance Equivalent Volume (Vas)5.3 ft.³
  • BL Product (BL)24.6 Tm
  • Diaphragm Mass Inc. Airload (Mms)150g
  • Maximum Linear Excursion (Xmax)8.5 mm
  • Surface Area of Cone (Sd)910 cm²
  • Cone MaterialPaper / Carbon Fiber
  • Surround MaterialCloth
  • Voice Coil FormerFiberglass
  • Magnet MaterialFerrite
  • Overall Outside Diameter15.5"
  • Baffle Cutout Diameter13.9"
  • Depth6.2"
  • # Mounting Holes8
  • Sealed Volume0.59 ft.³
  • Sealed F3111 Hz
  • Vented Volume1.16 ft.³
  • Vented F371 Hz
  • BrandRCF USA
  • ModelLF15G401
  • Part Number294-874
  • UPC844632090172
    (1 Reviews)
  • Weight33.356 lbs.
View similar products to the RCF LF15G401 15" Woofer Speaker
