RCF LF12N401 12" Neodymium Woofer Speaker
Brand:|Model: LF12N401|Part # 294-854
RCF's LF12N451 woofer is designed for reliable, linear performance with very low distortion.
  • Specially designed for concert touring systems
  • Strong, lightweight neodymium magnetic structure
  • 4" diameter inside/outside copper voice coil on fiberglass former
  • 1,600 watt continuous program power handling
  • Dual-forced air ventilation for minimum power compression
  • Straight-sided smooth cone geometry and single spider design
  • Perfect for professional bass reflex and horn-loaded systems
RCF's LF12N451 woofer is designed for reliable, linear performance with very low distortion. The same neodymium magnetic structure and 4" voice coil configuration as the LF18N401 18" transducer provides high power handling and output. A unique dual-forced air venting system promotes efficient voice coil ventilation to minimize power compression and maximize power handling. The LF12N401 is ideal for use in pro applications that require superior low frequency output in a very small cabinet volume.
  • Nominal Diameter12"
  • Power Handling (RMS)800 Watts
  • Power Handling (max)1600 Watts
  • Impedance8 ohms
  • Frequency Response45 to 2,000 Hz
  • Sensitivity96 dB 2.83V/1m
  • Voice Coil Diameter4"
  • Resonant Frequency (Fs)48 Hz
  • DC Resistance (Re)5.5 ohms
  • Voice Coil Inductance (Le)1.7 mH
  • Mechanical Q (Qms)9.1
  • Electromagnetic Q (Qes)0.21
  • Total Q (Qts)0.2
  • Compliance Equivalent Volume (Vas)1.77 ft.³
  • BL Product (BL)26 Tm
  • Diaphragm Mass Inc. Airload (Mms)78g
  • Maximum Linear Excursion (Xmax)7.3 mm
  • Surface Area of Cone (Sd)530 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Voice Coil FormerFiberglass
  • Magnet MaterialFerrite
  • Overall Outside Diameter12.6"
  • Baffle Cutout Diameter11.5"
  • Depth5.5"
  • # Mounting Holes8
  • Sealed Volume0.1 ft.³
  • Sealed F3235 Hz
  • Vented Volume0.2 ft.³
  • Vented F3156 Hz
  • BrandRCF USA
  • ModelLF12N401
  • Part Number294-854
  • UPC844632090073
  • Weight21.05 lbs.
View similar products to the RCF LF12N401 12" Neodymium Woofer Speaker
