RCF LF12G301 12" Woofer Speaker
Brand:|Model: LF12G301|Part # 294-844
The RCF LF12G301's excellent linear response, well controlled down to 50 Hz, makes it especially suitable for band-pass subwoofers and small size bass reflex systems.
List Price$364.00
You Save29%
$258.00
Part # 294-844
  • High BL low frequency driver with deep, punchy bass
  • 3" diameter inside/outside copper voice coil on fiberglass former
  • 900 watt continuous program power handling
  • Good sensitivity, low distortion
  • M-roll surround, optimized moving mass, and exponential cone geometry
The RCF LF12G301's excellent linear response, well controlled down to 50 Hz, makes it especially suitable for band-pass subwoofers and small size bass reflex systems. The driver is a very good solution for two or three way systems when good magnet force and bass punch are required.
  • Nominal Diameter12"
  • Power Handling (RMS)450 Watts
  • Power Handling (max)900 Watts
  • Impedance8 ohms
  • Frequency Response40 to 2,000 Hz
  • Sensitivity97 dB 2.83V/1m
  • Voice Coil Diameter3"
  • Resonant Frequency (Fs)43 Hz
  • DC Resistance (Re)5.8 ohms
  • Voice Coil Inductance (Le)2 mH
  • Mechanical Q (Qms)4.6
  • Electromagnetic Q (Qes)0.23
  • Total Q (Qts)0.22
  • Compliance Equivalent Volume (Vas)3.43 ft.³
  • BL Product (BL)19 Tm
  • Diaphragm Mass Inc. Airload (Mms)56g
  • Maximum Linear Excursion (Xmax)6.8 mm
  • Surface Area of Cone (Sd)530 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Voice Coil FormerFiberglass
  • Magnet MaterialFerrite
  • Overall Outside Diameter12.6"
  • Baffle Cutout Diameter11.5"
  • Depth5.4"
  • # Mounting Holes8
  • Sealed Volume0.23 ft.³
  • Sealed F3167 Hz
  • Vented Volume0.49 ft.³
  • Vented F3110 Hz
  • BrandRCF USA
  • ModelLF12G301
  • Part Number294-844
  • UPC844632090035
  • Weight18 lbs.
B&C 15HPL76 15" Neodymium Woofer
Part #  294-682
B&C 15PS100 15" Woofer
Part #  294-673
View similar products to the RCF LF12G301 12" Woofer Speaker
Part # 294-844
