RCF L8S800 8" Midbass Speaker
Brand:|Model: L8S800|Part # 294-828
Very high linearity and low distortion are special features of the L8S800 carbon fiber cone 8" transducer.
  • M-roll damped surround and exponential cone geometry
  • High strength, waterproof carbon fiber cone
  • 1-1/2" copper voice coil on polyimide former
  • Balanced midbass linearity/low frequency extension
  • Ideal for compact, extended range, bass reflex systems
Very high linearity and low distortion are special features of the L8S800 carbon fiber cone 8" transducer. RCF's use of an exponential profile carbon fiber cone of exceptional strength and light weight drastically reduces breakup, thus ensuring a high level of efficiency and excellent transient response. Maximum care in the selection of components and in the assembly process makes the L8S800 an extremely reliable driver. It is the ideal woofer for very compact, full range, bass reflex systems where a good balance between midbass linearity and low frequency extension is required. The L8S800's light mass and midrange extension make it perfect for combining with a small size HF driver or tweeter.
  • Nominal Diameter8"
  • Power Handling (RMS)170 Watts
  • Power Handling (max)340 Watts
  • Impedance8 ohms
  • Frequency Response50 to 4,000 Hz
  • Sensitivity93 dB 2.83V/1m
  • Voice Coil Diameter1.5"
  • Resonant Frequency (Fs)60 Hz
  • DC Resistance (Re)6.1 ohms
  • Voice Coil Inductance (Le)0.9 mH
  • Mechanical Q (Qms)4.1
  • Electromagnetic Q (Qes)0.46
  • Total Q (Qts)0.41
  • Compliance Equivalent Volume (Vas)0.78 ft.³
  • BL Product (BL)10.3 Tm
  • Diaphragm Mass Inc. Airload (Mms)21g
  • Maximum Linear Excursion (Xmax)5.8 mm
  • Surface Area of Cone (Sd)210 cm²
  • Cone MaterialCarbon Fiber
  • Surround MaterialCloth
  • Magnet MaterialFerrite
  • Overall Outside Diameter9.4"
  • Baffle Cutout Diameter7.24"
  • Depth3.7"
  • # Mounting Holes4
  • Sealed Volume0.22 ft.³
  • Sealed F3125 Hz
  • Vented Volume0.65 ft.³
  • Vented F368 Hz
  • BrandRCF USA
  • ModelL8S800
  • Part Number294-828
  • UPC844632089954
    (1 Reviews)
  • Weight8.35 lbs.
