RCF L18S801 18" Woofer Speaker
Brand:|Model: L18S801|Part # 294-882
A perfect blend of voice coil length, moving mass weight, and suspension control makes the RCF L18S801 the preferred solution for many speaker system manufacturers and production companies.
ORDER TODAY
Ships in 7-10 Business Days
List Price$580.00
You Save29%
$411.00
Part # 294-882
  • High efficiency low frequency driver
  • 4" diameter inside/outside copper voice coil on fiberglass former
  • 1,400 watt continuous program power handling
  • Double spider with silicon-based damping control
  • M-roll surround, optimized moving mass, and exponential cone geometry
A perfect blend of voice coil length, moving mass weight, and suspension control makes the RCF L18S801 the preferred solution for many speaker system manufacturers and production companies. Voice coil construction, suspension, and cone materials are engineered to withstand up to 700 watts RMS power. The L18S801 finds its best application in bandpass, reflex-horn, and horn-loaded systems. It is a perfect compact bass reflex solution for live music, when maximum punch is required.
  • Nominal Diameter18"
  • Power Handling (RMS)700 Watts
  • Power Handling (max)1400 Watts
  • Impedance8 ohms
  • Frequency Response38 to 1,000 Hz
  • Sensitivity99.5 dB 2.83V/1m
  • Voice Coil Diameter4"
  • Resonant Frequency (Fs)39 Hz
  • DC Resistance (Re)4.9 ohms
  • Voice Coil Inductance (Le)1.7 mH
  • Mechanical Q (Qms)8.3
  • Electromagnetic Q (Qes)0.3
  • Total Q (Qts)0.29
  • Compliance Equivalent Volume (Vas)7.27 ft.³
  • BL Product (BL)24.5 Tm
  • Diaphragm Mass Inc. Airload (Mms)148g
  • Maximum Linear Excursion (Xmax)6.8 mm
  • Surface Area of Cone (Sd)1130 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Voice Coil FormerFiberglass
  • Magnet MaterialFerrite
  • Overall Outside Diameter18.5"
  • Baffle Cutout Diameter16.4"
  • Depth8.3"
  • # Mounting Holes8
  • Sealed Volume1.05 ft.³
  • Sealed F3107 Hz
  • Vented Volume2.09 ft.³
  • Vented F368 Hz
  • BrandRCF USA
  • ModelL18S801
  • Part Number294-882
  • UPC844632090219
    (1 Reviews)
  • Weight33.0000 lbs.
View similar products to the RCF L18S801 18" Woofer Speaker
