RCF L18P300-ND 18" Neodymium Woofer Speaker
Brand:|Part # 294-884
The L18P300-ND is an evolution of RCF's legendary L18P300 but with a high flux density neodymium magnetic design.
  • High BL low frequency neodymium driver with deep, punchy bass
  • 4" diameter inside/outside copper voice coil on fiberglass former
  • 2,000 watt continuous program power handling
  • Forced air ventilation and 15 mm top plate for minimum power compression
  • Dual spider design with silicon-based dampening control
  • M-roll surround, optimized moving mass, and exponential cone geometry
  • Good sensitivity, low distortion, extraordinary definition
The L18P300-ND is an evolution of RCF's legendary L18P300 but with a high flux density neodymium magnetic design. It is manufactured with a newly designed aluminum basket that provides excellent voice coil ventilation, thereby increasing power handling and reducing compression. A specially designed M-roll suspension, combined with a double silicon spider, ensures linear piston control and undistorted low frequency reproduction at very high power. The L18P300-ND is perfectly compatible with the ferrite version for size and performance, but with half the weight.
  • Nominal Diameter18"
  • Power Handling (RMS)1,000 Watts
  • Power Handling (max)2000 Watts
  • Impedance8 ohms
  • Frequency Response35 to 1,000 Hz
  • Sensitivity97 dB 2.83V/1m
  • Voice Coil Diameter4"
  • Resonant Frequency (Fs)33 Hz
  • DC Resistance (Re)5 ohms
  • Voice Coil Inductance (Le)1.9 mH
  • Mechanical Q (Qms)8.3
  • Electromagnetic Q (Qes)0.33
  • Total Q (Qts)0.32
  • Compliance Equivalent Volume (Vas)8.12 ft.³
  • BL Product (BL)23.5 Tm
  • Diaphragm Mass Inc. Airload (Mms)180g
  • Maximum Linear Excursion (Xmax)7.8 mm
  • Surface Area of Cone (Sd)1130 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Voice Coil FormerFiberglass
  • Magnet MaterialFerrite
  • Overall Outside Diameter18.1"
  • Baffle Cutout Diameter16.3"
  • Depth8.1"
  • # Mounting Holes8
  • Sealed Volume1.23 ft.³
  • Sealed F388 Hz
  • Vented Volume2.93 ft.³
  • Vented F355 Hz
  • BrandRCF USA
  • Part Number294-884
  • UPC844632090226
  • Weight19.2 lbs.
View similar products to the RCF L18P300-ND 18" Neodymium Woofer Speaker
