RCF L18P200-N 18" Woofer Speaker
Brand:|Model: L18P200-N|Part # 294-880
The L18P200-N is RCF's classical extended low frequency 18" woofer. Generous voice coil length, higher moving mass, and very low resonance provide perfect low frequency reproduction.
  • Remarkable linearity in its application range
  • 4" diameter inside/outside copper voice coil on fiberglass former
  • 1,600 watt continuous program power handling
  • Triple-roll damped surround
  • Corrugated straight damped cone
  • Optimized for bass reflex enclosures
The L18P200-N is RCF's classical extended low frequency 18" woofer. Generous voice coil length, higher moving mass, and very low resonance provide perfect low frequency reproduction. Special treatments are applied to the cone surface and surround for optimum dampening. The L18P200-N finds its best application in bass reflex enclosures. It is a perfect solution for live performance, recorded music, cinema subwoofers, critical monitoring, and all other applications where very low frequency linearity is required. Popular replacement for the RCF/EAW LC-1814 driver used in EAW SB850 (shallow version) and EAW Cinema Series subwoofer systems.
  • Nominal Diameter18"
  • Power Handling (RMS)800 Watts
  • Power Handling (max)1600 Watts
  • Impedance8 ohms
  • Frequency Response27 to 1,000 Hz
  • Sensitivity96 dB 2.83V/1m
  • Voice Coil Diameter4"
  • Resonant Frequency (Fs)28 Hz
  • DC Resistance (Re)6.3 ohms
  • Voice Coil Inductance (Le)2.2 mH
  • Mechanical Q (Qms)7.1
  • Electromagnetic Q (Qes)0.32
  • Total Q (Qts)0.31
  • Compliance Equivalent Volume (Vas)13.42 ft.³
  • BL Product (BL)23.1 Tm
  • Diaphragm Mass Inc. Airload (Mms)155g
  • Maximum Linear Excursion (Xmax)9.8 mm
  • Surface Area of Cone (Sd)1130 cm²
  • Cone MaterialCoated Paper
  • Surround MaterialCloth
  • Voice Coil FormerFiberglass
  • Magnet MaterialFerrite
  • Overall Outside Diameter18.5"
  • Baffle Cutout Diameter16.4"
  • Depth7.1"
  • # Mounting Holes8
  • Sealed Volume1.87 ft.³
  • Sealed F350 Hz
  • Vented Volume4.39 ft.³
  • Vented F331 Hz
  • BrandRCF USA
  • ModelL18P200-N
  • Part Number294-880
  • UPC844632090202
    (1 Reviews)
  • Weight30.7 lbs.
View similar products to the RCF L18P200-N 18" Woofer Speaker
