RCF L15S801 15" Woofer Speaker
Brand:|Model: L15S801|Part # 294-864
A perfect blend of voice coil length, moving mass weight, and suspension control makes the RCF L15S801 the preferred solution for many speaker system manufacturers and production companies.
List Price$537.00
You Save29%
$381.00
Part # 294-864
  • High efficiency low frequency driver
  • 4" diameter inside/outside copper voice coil on fiberglass former
  • 1,400 watt continuous program power handling
  • Double spider with silicon-based dampening control
  • M-roll surround, optimized moving mass, and exponential cone geometry
A perfect blend of voice coil length, moving mass weight, and suspension control makes the RCF L15S801 the preferred solution for many speaker system manufacturers and production companies. Voice coil construction, suspension, and cone materials are engineered to withstand up to 700 watts RMS power. The L15S801 finds its best application in bandpass, reflex-horn, and horn-loaded systems. It is a perfect compact bass reflex solution for live music, when maximum punch is required.
  • Nominal Diameter15"
  • Power Handling (RMS)700 Watts
  • Power Handling (max)1400 Watts
  • Impedance8 ohms
  • Frequency Response40 to 1,500 Hz
  • Sensitivity99.5 dB 2.83V/1m
  • Voice Coil Diameter4"
  • Resonant Frequency (Fs)48 Hz
  • DC Resistance (Re)6.1 ohms
  • Voice Coil Inductance (Le)1.7 mH
  • Mechanical Q (Qms)11
  • Electromagnetic Q (Qes)0.33
  • Total Q (Qts)0.32
  • Compliance Equivalent Volume (Vas)3.99 ft.³
  • BL Product (BL)23.6 Tm
  • Diaphragm Mass Inc. Airload (Mms)100g
  • Maximum Linear Excursion (Xmax)5.5 mm
  • Surface Area of Cone (Sd)850 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Voice Coil FormerFiberglass
  • Magnet MaterialFerrite
  • Overall Outside Diameter15.2"
  • Baffle Cutout Diameter13.9"
  • Depth5.4"
  • # Mounting Holes8
  • Sealed Volume0.6 ft.³
  • Sealed F3128 Hz
  • Vented Volume1.44 ft.³
  • Vented F379 Hz
  • BrandRCF USA
  • ModelL15S801
  • Part Number294-864
  • UPC844632090127
  • Weight27.5 lbs.
View similar products to the RCF L15S801 15" Woofer Speaker
Part # 294-864
