RCF L15P540 15" Woofer Speaker
Brand:|Model: L15P540|Part # 294-860
High power 15" woofer. Very good power handling, excellent linearity, and very low distortion.
Awaiting Updated Due Date
List Price$472.00
You Save29%
Part # 294-860
  • High BL low frequency driver with deep, punchy bass
  • 3" diameter inside/outside copper voice coil on fiberglass former
  • 1,000 watt continuous program power handling
  • Good sensitivity, low distortion
  • Double spider with silicon-based dampening control
  • M-roll surround, optimized moving mass, and exponential cone geometry
High power 15" woofer. Very good power handling, excellent linearity, and very low distortion. Heat sinking is integrated into the cast basket, which in conjunction with the sealed dual spider ensures efficient heat dissipation. The driver's excellent linear response, well controlled down to 40 Hz, makes the L15P540 especially suitable for horn-loaded applications, band-pass enclosures, and small size bass reflex systems. It is a very good solution for two or three way systems when a very high BL and maximum punch is required. Popular replacement driver for many EAW speaker systems.
  • Nominal Diameter15"
  • Power Handling (RMS)500 Watts
  • Power Handling (max)1000 Watts
  • Impedance8 ohms
  • Frequency Response40 to 2,000 Hz
  • Sensitivity98 dB 2.83V/1m
  • Voice Coil Diameter3"
  • Resonant Frequency (Fs)50 Hz
  • DC Resistance (Re)5.6 ohms
  • Voice Coil Inductance (Le)1.5 mH
  • Mechanical Q (Qms)9.7
  • Electromagnetic Q (Qes)0.41
  • Total Q (Qts)0.39
  • Compliance Equivalent Volume (Vas)3.53 ft.³
  • BL Product (BL)21.4 Tm
  • Diaphragm Mass Inc. Airload (Mms)106g
  • Maximum Linear Excursion (Xmax)6.5 mm
  • Surface Area of Cone (Sd)850 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Voice Coil FormerFiberglass
  • Magnet MaterialFerrite
  • Overall Outside Diameter15.2"
  • Baffle Cutout Diameter13.9"
  • Depth6.4"
  • # Mounting Holes8
  • Sealed Volume0.86 ft.³
  • Sealed F3110 Hz
  • Vented Volume2.48 ft.³
  • Vented F362 Hz
  • BrandRCF USA
  • ModelL15P540
  • Part Number294-860
  • UPC844632090103
  • Weight22 lbs.
Pyle PBW10S 10" Midbass
Part #  292-2528
B&C 12NW76 12" Neodymium Woofer
Part #  294-681
B&C 6PS38 6.5" Professional Woofer 8 Ohm
Part #  294-5906
View similar products to the RCF L15P540 15" Woofer Speaker
Part # 294-860
