RCF L15P530 15" Midbass Speaker
Brand:|Model: L15P530|Part # 294-858
The RCF L15P530 is a very high sensitivity midbass driver with excellent linearity and low distortion.
ORDER TODAY
Ships in 7-10 Business Days
List Price$429.00
You Save29%
$304.00
Part # 294-858
  • Midbass driver with linear on-axis response past 3 kHz
  • 3" diameter edgewound aluminum voice coil
  • 700 watt continuous program power handling
  • High sensitivity, low distortion
  • Silicon damped spider
  • M-roll surround and exponential cone geometry
The RCF L15P530 is a very high sensitivity midbass driver with excellent linearity and low distortion. Efficient heat dissipation in ensured by a radiator that is part of the L15P530's basket. Air is forced into the radiator thanks to a sealed spider design. A very light moving mass and a linear response curve past 3 kHz make the L15P530 an ideal solution for high quality 2-way or 3-way systems. The aluminum voice coil guarantees high efficiency in conjunction with a proper Q factor for good bass response.
  • Nominal Diameter15"
  • Power Handling (RMS)350 Watts
  • Power Handling (max)700 Watts
  • Impedance8 ohms
  • Frequency Response40 to 3,000 Hz
  • Sensitivity100 dB 2.83V/1m
  • Voice Coil Diameter3"
  • Resonant Frequency (Fs)45 Hz
  • DC Resistance (Re)5.1 ohms
  • Voice Coil Inductance (Le)1.45 mH
  • Mechanical Q (Qms)7.5
  • Electromagnetic Q (Qes)0.51
  • Total Q (Qts)0.48
  • Compliance Equivalent Volume (Vas)5.65 ft.³
  • BL Product (BL)15.3 Tm
  • Diaphragm Mass Inc. Airload (Mms)83g
  • Maximum Linear Excursion (Xmax)6.5 mm
  • Surface Area of Cone (Sd)850 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Magnet MaterialFerrite
  • Overall Outside Diameter15.2"
  • Baffle Cutout Diameter13.9"
  • Depth6.4"
  • # Mounting Holes8
  • Sealed Volume2.95 ft.³
  • Sealed F376 Hz
  • Vented Volume8.14 ft.³
  • Vented F338 Hz
  • BrandRCF USA
  • ModelL15P530
  • Part Number294-858
  • UPC844632090097
  • Weight22.25 lbs.
View similar products to the RCF L15P530 15" Midbass Speaker
Part # 294-858
