RCF L15P200AK 15" Woofer Speaker
Brand:|Model: L15P200AK|Part # 294-868
The L15P200AK woofer's generous voice coil length, heavier moving mass, and very low resonance combine for perfect low frequency reproduction.
- Order Soon - Only 3 Left In Stock
List Price$537.00
You Save29%
$381.00
Part # 294-868
  • High performance tour-grade low frequency transducer
  • 4" diameter inside/outside copper voice coil on fiberglass former
  • 1,600 watt continuous program power handling
  • Triple roll surround and corrugated straight damped cone
  • Excellent replacement driver for the EAW KF850 system
The L15P200AK woofer's generous voice coil length, heavier moving mass, and very low resonance combine for perfect low frequency reproduction. Remarkable linearity in the application range. Special treatments are applied to the cone surface and surround for optimum dampening characteristics. The L15P200AK finds its best application in bass reflex enclosures. It is a perfect solution for recorded music, cinema speakers, very low frequency monitoring, and applications where superb low frequency linearity is required. In 2-way systems, the L15P200AK works well when used in conjunction with large format compression drivers—also very good for high output 3-way systems. Popular replacement for the RCF/EAW LC-1514 low-mid driver found in the EAW KF850 loudspeaker system.
  • Nominal Diameter15"
  • Power Handling (RMS)800 Watts
  • Power Handling (max)1600 Watts
  • Impedance8 ohms
  • Frequency Response35 to 1,000 Hz
  • Sensitivity95 dB 2.83V/1m
  • Voice Coil Diameter4"
  • Resonant Frequency (Fs)38 Hz
  • DC Resistance (Re)5.9 ohms
  • Voice Coil Inductance (Le)2.2 mH
  • Mechanical Q (Qms)6.8
  • Electromagnetic Q (Qes)0.38
  • Total Q (Qts)0.35
  • Compliance Equivalent Volume (Vas)4.91 ft.³
  • BL Product (BL)21.2 Tm
  • Diaphragm Mass Inc. Airload (Mms)121g
  • Maximum Linear Excursion (Xmax)9.8 mm
  • Surface Area of Cone (Sd)830 cm²
  • Cone MaterialCoated Paper
  • Surround MaterialCloth
  • Voice Coil FormerFiberglass
  • Magnet MaterialFerrite
  • Overall Outside Diameter15.2"
  • Baffle Cutout Diameter14.1"
  • Depth5.4"
  • # Mounting Holes8
  • Sealed Volume0.92 ft.³
  • Sealed F393 Hz
  • Vented Volume2.4 ft.³
  • Vented F355 Hz
  • BrandRCF USA
  • ModelL15P200AK
  • Part Number294-868
  • UPC844632090141
  • Weight26.8 lbs.
View similar products to the RCF L15P200AK 15" Woofer Speaker
Part # 294-868
