RCF L15/554K 15" Woofer Speaker
Brand:|Model: L15/554K|Part # 294-866
Very high efficiency and good linearity are distinctive features of the RCF L15/554K midbass woofer.
List Price$580.00
You Save29%
$411.00
Part # 294-866
  • High efficiency midbass and low frequency driver
  • 4" diameter inside/outside copper voice coil on fiberglass former
  • 1,200 watt continuous program power handling
  • M-roll surround, optimized moving mass, and exponential cone geometry
  • Copper ring controls inductance
Very high efficiency and good linearity are distinctive features of the RCF L15/554K midbass woofer. The L15/554K is designed to be mounted in compact sized bass reflex enclosures. A well-engineered combination of voice coil length, low moving mass, and superior suspension control makes the L15/554K an excellent choice for high power 2-way systems. Thanks to a very high BL/Re ratio, small mechanical depth, and a strong cone, this transducer is a good solution for horn-loaded or hybrid horn-loaded systems. Popular replacement woofer for the EAW BH500, BH215, and FR350 loudspeaker systems.
  • Nominal Diameter15"
  • Power Handling (RMS)600 Watts
  • Power Handling (max)1200 Watts
  • Impedance8 ohms
  • Frequency Response40 to 2,000 Hz
  • Sensitivity99 dB 2.83V/1m
  • Voice Coil Diameter4"
  • Resonant Frequency (Fs)35 Hz
  • DC Resistance (Re)6.6 ohms
  • Voice Coil Inductance (Le)1.7 mH
  • Mechanical Q (Qms)8.6
  • Electromagnetic Q (Qes)0.25
  • Total Q (Qts)0.24
  • Compliance Equivalent Volume (Vas)8.02 ft.³
  • BL Product (BL)23 Tm
  • Diaphragm Mass Inc. Airload (Mms)91g
  • Maximum Linear Excursion (Xmax)5.8 mm
  • Surface Area of Cone (Sd)830 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Voice Coil FormerFiberglass
  • Magnet MaterialFerrite
  • Overall Outside Diameter15.2"
  • Baffle Cutout Diameter14.6"
  • Depth5.4"
  • # Mounting Holes8
  • Sealed Volume0.64 ft.³
  • Sealed F3125 Hz
  • Vented Volume1.41 ft.³
  • Vented F381 Hz
  • BrandRCF USA
  • ModelL15/554K
  • Part Number294-866
  • UPC844632090134
  • Weight28.15 lbs.
View similar products to the RCF L15/554K 15" Woofer Speaker
Part # 294-866
