RCF L12P110K 12" Midbass Speaker
Brand:|Model: L12P110K|Part # 294-850
The RCF L12P110K is specially designed for compact sized bass reflex enclosures.
ORDER TODAY
Ships in 7-10 Business Days
List Price$494.00
You Save29%
$350.00
Part # 294-850
  • High efficiency midbass driver
  • 4" copper voice coil wound inside/outside on a fiberglass former
  • 1,000 watt continuous program power handling
  • Very high sensitivity and very low distortion
  • M-roll surround, light moving mass, and exponential cone geometry
The RCF L12P110K is specially designed for compact sized bass reflex enclosures. Very high efficiency and low distortion are special features of this 12" midbass transducer. Special treatments are applied to cone surface and surround for optimum dampening. The unique combination of a short voice coil and very high BL/Re ratio makes the L12P100K a very good choice when fast and precise midbass reproduction is required. Great results in high power horn loaded applications.
  • Nominal Diameter12"
  • Power Handling (RMS)500 Watts
  • Power Handling (max)1000 Watts
  • Impedance8 ohms
  • Frequency Response60 to 2,000 Hz
  • Sensitivity101 dB 2.83V/1m
  • Voice Coil Diameter4"
  • Resonant Frequency (Fs)44 Hz
  • DC Resistance (Re)5.6 ohms
  • Voice Coil Inductance (Le)1 mH
  • Mechanical Q (Qms)4.3
  • Electromagnetic Q (Qes)0.14
  • Total Q (Qts)0.13
  • Compliance Equivalent Volume (Vas)3.46 ft.³
  • BL Product (BL)25 Tm
  • Diaphragm Mass Inc. Airload (Mms)55g
  • Maximum Linear Excursion (Xmax)3 mm
  • Surface Area of Cone (Sd)530 cm²
  • Cone MaterialTreated Paper
  • Surround MaterialCloth
  • Voice Coil FormerFiberglass
  • Magnet MaterialFerrite
  • Overall Outside Diameter12.3"
  • Baffle Cutout Diameter11.3"
  • Depth4.5"
  • # Mounting Holes8
  • Sealed Volume0.1 ft.³
  • Sealed F3259 Hz
  • Vented Volume0.16 ft.³
  • Vented F3184 Hz
  • BrandRCF USA
  • ModelL12P110K
  • Part Number294-850
  • UPC844632090059
  • Weight25 lbs.
View similar products to the RCF L12P110K 12" Midbass Speaker
Part # 294-850
