RCF L12L750 12" Midbass Speaker
Brand:|Model: L12L750|Part # 294-852
Very high efficiency and extended linearity are special features of RCF's L12L750 midbass transducer.
ORDER TODAY
Ships in 7-10 Business Days
List Price$537.00
You Save29%
$381.00
Part # 294-852
  • Professional/concert touring midbass driver
  • 4" edgewound aluminum voice coil on a fiberglass former
  • 700 watt continuous program power handling
  • High sensitivity and low distortion
  • Shaped shallow triple-roll damped surround
  • Primarily designed to be horn loaded in medium and long throw systems
  • Inverted dust cap minimizes cone distortion, improves coupling to a phase plug
Very high efficiency and extended linearity are special features of RCF's L12L750 midbass transducer. Efficient heat dissipation is ensured by a radiator that is part of the basket design. The aluminum voice coil provides a properly aligned Q factor and high sensitivity. A specially designed shallow triple-roll surround guarantees low midrange distortion, and a fiberglass former voice coil, polycotton suspensions, and treated cone contribute to the L12L750's very high power handling. When mounted in compact size bass reflex enclosures, the good combination of short voice coil, very low mass, and suspension control makes the L12L750 an excellent choice for high power, 2-way satellite applications.
  • Nominal Diameter12"
  • Power Handling (RMS)350 Watts
  • Power Handling (max)700 Watts
  • Impedance8 ohms
  • Frequency Response60 to 2,000 Hz
  • Sensitivity101 dB 2.83V/1m
  • Voice Coil Diameter4"
  • Resonant Frequency (Fs)62 Hz
  • DC Resistance (Re)5.2 ohms
  • Voice Coil Inductance (Le)1.25 mH
  • Mechanical Q (Qms)4.1
  • Electromagnetic Q (Qes)0.29
  • Total Q (Qts)0.27
  • Compliance Equivalent Volume (Vas)1.84 ft.³
  • BL Product (BL)18.8 Tm
  • Diaphragm Mass Inc. Airload (Mms)50g
  • Maximum Linear Excursion (Xmax)3.5 mm
  • Surface Area of Cone (Sd)530 cm²
  • Cone MaterialTreated Paper
  • Surround MaterialCloth
  • Voice Coil FormerFiberglass
  • Magnet MaterialFerrite
  • Overall Outside Diameter12.6"
  • Baffle Cutout Diameter11.3"
  • Depth5.7"
  • # Mounting Holes8
  • Sealed Volume0.23 ft.³
  • Sealed F3183 Hz
  • Vented Volume0.45 ft.³
  • Vented F3117 Hz
  • BrandRCF USA
  • ModelL12L750
  • Part Number294-852
  • UPC844632090066
  • Weight26.4 lbs.
RCF L15S801 15" Woofer Speaker
Part #  294-864
RCF L15/554K 15" Woofer Speaker
Part #  294-866
View similar products to the RCF L12L750 12" Midbass Speaker
Part # 294-852
