RCF L10/750YK 10" Midbass Speaker
Brand:|Model: L10/750YK|Part # 294-836
The RCF L10-750YK is a professional mid-bass woofer featuring very high output and dynamics.
List Price$343.00
You Save29%
Part # 294-836
  • 3" fiberglass inside/outside copper voice coil
  • 700 watt continuous program power handling
  • 100 dB sensitivity
  • 70 Hz – 3 kHz frequency range
  • Shaped M-roll damped surround
  • Used in some of the most popular concert systems
The RCF L10-750YK is a professional mid-bass woofer featuring very high output and dynamics. Implementation of a 3" voice coil, fiberglass former, and copper wire winding has enabled considerable improvement in transient peak response and extension of mid-high frequencies. A specially designed M-roll surround guarantees low midrange distortion and perfect damping of spurious resonances. The L10-750YK is primarily designed to be horn loaded in medium and long throw systems. When mounted in compact size bass reflex enclosures, the combination of short voice coil, very low mass, and suspension control makes the L10-750YK a good choice for high power, 2-way satellite applications. Popular replacement for the RCF/EAW 804022 midrange driver found in EAW KF650 and KF850 loudspeaker systems.
  • Nominal Diameter10"
  • Power Handling (RMS)350 Watts
  • Power Handling (max)700 Watts
  • Impedance8 ohms
  • Frequency Response70 to 3,000 Hz
  • Sensitivity100 dB 2.83V/1m
  • Voice Coil Diameter3"
  • Resonant Frequency (Fs)68 Hz
  • DC Resistance (Re)5.1 ohms
  • Voice Coil Inductance (Le)1.5 mH
  • Mechanical Q (Qms)4.2
  • Electromagnetic Q (Qes)0.25
  • Total Q (Qts)0.24
  • Compliance Equivalent Volume (Vas)0.92 ft.³
  • BL Product (BL)17.5 Tm
  • Diaphragm Mass Inc. Airload (Mms)36g
  • Maximum Linear Excursion (Xmax)2.5 mm
  • Surface Area of Cone (Sd)350 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Voice Coil FormerFiberglass
  • Magnet MaterialFerrite
  • Overall Outside Diameter10.6"
  • Baffle Cutout Diameter9.1"
  • Depth4.7"
  • # Mounting Holes8
  • Sealed Volume0.07 ft.³
  • Sealed F3242 Hz
  • Vented Volume0.16 ft.³
  • Vented F3157 Hz
  • BrandRCF USA
  • ModelL10/750YK
  • Part Number294-836
  • UPC844632089992
  • Weight17.8 lbs.
View similar products to the RCF L10/750YK 10" Midbass Speaker
Part # 294-836
