RCF L10/568H 10" Midbass Speaker
Brand:|Model: L10/568H|Part # 294-834
High efficiency 10" mid-bass. Very high sensitivity, excellent linearity. A copper ring helps reduce distortion and smoothes the response up to 3 kHz.
  • 2" inside/outside copper voice coil
  • 400 watts continuous program power handling
  • 97.5 dB sensitivity
  • 50 Hz – 3 kHz frequency range
  • M-roll surround and exponential cone geometry
  • Copper ring lowers inductance and distortion
High efficiency 10" mid-bass. Very high sensitivity, excellent linearity. A copper ring helps reduce distortion and smoothes the response up to 3 kHz. The 2" copper voice coil guarantees high power handling and perfect low frequency control. A light moving mass and a frequency response linear above 3 kHz make the L10-568H a good solution for high quality two way systems.
  • Nominal Diameter10"
  • Power Handling (RMS)200 Watts
  • Power Handling (max)400 Watts
  • Impedance8 ohms
  • Frequency Response50 to 3,000 Hz
  • Sensitivity97.5 dB 2.83V/1m
  • Voice Coil Diameter2"
  • Resonant Frequency (Fs)70 Hz
  • DC Resistance (Re)5.1 ohms
  • Voice Coil Inductance (Le)1.05 mH
  • Mechanical Q (Qms)6
  • Electromagnetic Q (Qes)0.41
  • Total Q (Qts)0.38
  • Compliance Equivalent Volume (Vas)1.04 ft.³
  • BL Product (BL)12.8 Tm
  • Diaphragm Mass Inc. Airload (Mms)30g
  • Maximum Linear Excursion (Xmax)4.3 mm
  • Surface Area of Cone (Sd)350 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter10.2"
  • Baffle Cutout Diameter9.1"
  • Depth4.5"
  • # Mounting Holes8
  • Sealed Volume0.24 ft.³
  • Sealed F3158 Hz
  • Vented Volume0.67 ft.³
  • Vented F389 Hz
  • BrandRCF USA
  • ModelL10/568H
  • Part Number294-834
  • UPC844632089985
  • Weight12.3 lbs.
View similar products to the RCF L10/568H 10" Midbass Speaker
Part # 294-834
