294-920_ALT_0
RCF 13360051 Phase Plug for MR10N301 Midbass Speaker
Brand:|Model: 13360051|Part # 294-920
Precision phase correction device for horn loaded RCF 10" midbass drivers.
- Order Soon - Only 3 Left In Stock
List Price$49.00
You Save34%
$32.43
Buy 4+$29.97
Part # 294-920
  • Optimizes horn loaded midrange designs that employ RCF 10" drivers
  • Compensates for offset arrival times in the horn's throat
  • Improves efficiency, linearity, and driver loading
  • Expertly engineered, cast resin construction
Precision phase correction device for horn loaded RCF 10" midbass drivers. Supported by five integral arms, the mathematically optimized center plug "hugs" a driver's center dome and corrects the time alignment mismatches that exist in the geometry between the driver's cone/dome, the driver's surround, and the horn's throat. Compensation for these errors results in improved efficiency and elimination of nulls in the passband. Fits MR10N301 and L10/750YK models; may be shimmed or trimmed to fit others as well. Cast resin construction.
Dimensions: • Outside diameter of flange: 10" • Inside diameter of flange: 9-1/4" • Diameter of phase plug: 4-1/8" • Length of phase plug: 4-1/2" • Depth of phase plug relative to bottom of mounting flange, facing the driver: 1" at phase plug rim, 1/2" at phase plug center • Depth of phase plug relative to bottom of mounting flange, facing the horn: 3-1/2" (tip to bottom of flange).
  • Mounting TypeSpecial
  • ConstructionPolycarbonate
  • BrandRCF USA
  • Model13360051
  • Part Number294-920
  • UPC844632090424
  • Product CategoryHorns & Waveguides
    (1 Reviews)
  • Weight2.65 lbs.
View similar products to the RCF 13360051 Phase Plug for MR10N301 Midbass Speaker
in the Horns & Waveguides product category.
