RCA WHP141B Wireless Headphones
Brand:|Model: WHP141B|Part # 182-212
Break the chain of headphone cables with RCA's WHP141 stereo wireless headphones.
List Price$69.95
You Save29%
$49.90
Part # 182-212
  • 150 ft. operating distance—even through walls and floors
  • Includes base/transmitter, headphones, batteries, and power supply
  • Large 40 mm headphone drivers
  • 900 MHz transmitting frequency
  • Three selectable operating channels for reduced interference
Break the chain of headphone cables with RCA's WHP141 stereo wireless headphones. PLL technology is featured on both the transmitter and headphones lock in the transmitting frequency for crystal clear reception. Frequency interference is reduced with three selectable channels. Unlike IR (infrared) headphones that require line-of-sight between the headphones and transmitter base, the WHP141s offer accurate signal transmission using radio frequency for total freedom of movement up to 150 ft. from the transmitter—through walls, doors, and ceilings. 40 mm headphone drivers are used for a wide frequency response of 30-12,500 Hz. Includes
  • Special FeaturesBluetooth / Wireless,Volume Control
  • Fit StyleOver-the-Ear
  • Type or Typical UseHi-Fi / Portables
  • ColorBlack
  • BrandRCA
  • ModelWHP141B
  • Part Number182-212
  • UPC079000332343
  • Product CategoryHeadphones
    (8 Reviews)
  • Weight1.25 lbs.
View similar products to the RCA WHP141B Wireless Headphones
in the Headphones product category.
RCA WHP141B Wireless Headphones is rated 3.625 out of 5 by 8.
Rated 4 out of 5 by from Works great - with correct partsThis product is easy to use and works great, but you need the following components that do not come with it:090-318 3.5MM STEREO TO 3.5MM STEREO COUPLER METAL240-065 3.5MM SLIM-PLUG MALE TO 2 X RCA MALE ADAPTER CABLE 5 FT.These parts are not that exprensive, but are needed if you are to get this product to work. Great father's day gift.
Date published: 2014-04-28
Rated 3 out of 5 by from Read The Manual!I purchased these headphones several months ago and had to send them back because I could not get the base to power on. In talking to tech support they agreed that the unit was defective and to return it for a replacement. The replacement did the exact same thing. Just by accident I was able to get it to work by turning up the volume of the source audio. I had read the manual but the section describing the need to have at least some audio signal coming in, which then triggers the power circuit to come on, was not as clear as I feel it should be. Reducing the volume below a certain level will cause the base to power off. That's too bad since sometimes it is necessary to listen at low settings. After figuring all that out the headphones have been functioning nicely. The audio quality is not really Hi-Fi but not bad either. They are lightweight but because of that are also a little flimsy. I doubt if these will last more than a year. Instead of this model I would suggest the higher priced alternatives such as the Sennheiser models. Just wish tech support knew a little more about these because it would have saved me about a month of time, and the headache of packing and shipping the "defective" unit back.
Date published: 2012-09-20
Rated 4 out of 5 by from Good headphonesOverall, I'm highly satisfied with these. The only problem I've had so far, the first sat of batteries only lasted 5 hours on a charge, while my older RCA phones would last several months on the same pair of batteries. I'm reserving final judgement until I try a set of new batteries and see if they last longer.
Date published: 2012-01-20
Rated 5 out of 5 by from Excellent value, one minor problemUpon receiving these headphones my wife tried to put in the supplied batteries. That is the only problem she found with the headphones, getting into the battery compartment is a major PIA, she could not and neither could I. So we called up Parts Express and they replaced the headset, allowing cross-shipping and even paid for the return. Upon receiving the second headset, same problem, However this time my wife pleaded, enough, just open the compartment anyway I could. She was not about to ask Parts Express to replace them again for something that is a minor design flaw, opening the battery compartment. I did get it open without damage and nowShe loves her headset, wears them because I have to get to sleep early. I can tell you I do not hear any sound from them and she is very contented listening to her white noise - the TV.I even tried them out and these are really great and excellent sound. While they are not 400 dollar headphones, they are an excellent value for our purposes.
Date published: 2011-09-22
Rated 4 out of 5 by from Great for dollar valueI have had a set of the WHP151 headphones for 5 years. Still have the original rechargable batterries in them.Have never had a battery problem and have worn them for hours.They look the same as the new WHP141
Date published: 2009-03-02
Rated 2 out of 5 by from earphones good, headband brokeI bought a set of wireless RCA headphones about 2 years ago, sill working great, use 1 to 3 x's a month. Last time I used them the plastic headbandbroke in two, making them worthless. The store where I bought them no longer carries them so I'mleft with broken $75 earphones. Think I'll buy a different brand next time.
Date published: 2008-12-17
  • 2016-02-10T06:54CST
  • co_hasreviews, tv_0, tr_8
  • loc_en_US, sid_182-212, PRD, sort_mostRecent
1. How tall is the charging unit?.  I need measure WITH  and WITHOUT the headphones .My space is only 7" 2.  Can I use regular (not rechargeable batteries) in the headphones.? If I can use regular, I would not have to put the headphone on the charger.
Asked by: M J E
Does this have a rechargeable stand , I do not want to have to buy batteries every few hours . Do you use rechargeable battries
Asked by: Katey
These have a rechargeable stand and batteries. The stand plugs into the headphones and charges them within a few hours.
Date published: 2015-09-15
(a) Can two RCA wireless headphone be used simultaneously with the same receiver? (b) Does RCA sell a separate charger for the second headphone?
Asked by: MichaelW
a - Yes, you can have multiple RCA wireless hp to sink / listen to a single transmitter.b - No, RCA doesn't sell separate charger.Hope this answer to your question and enjoy your RCA wireless headphone.
Answered by: 808 Audio
Date published: 2015-08-21
where do i find head strap for a RCA whip 141 wireless head phone wireless 900
Asked by: marsh
This is something you will only be able to get from RCA directly.
Date published: 2015-02-25
Is the RCA whp 141b, audio cable hard wired to the base transmitter
Asked by: Stanislaus
Yes the 3.5mm input cable is hard wired to the base.
Date published: 2015-02-24
How does a person open the battery compartment
Asked by: cgHAGER
The outside cover on the right side ear cup needs to be twisted counter clockwise. This can be relatively tight the first few times you remove it.
Date published: 2015-01-07
  • 2016-02-10T07:49CST
  • co_hasquestionsanswers, tq_10
  • loc_en_US, sid_182-212, PRD, sort_recentQuestionsFirst
