091-1060_ALT_0
091-1060_ALT_1
RCA Male Crimp-On Connector For RG-6/U & Quad
The video RCA connector offers maximum versatility for the Audio/Video Contractor.
  • Securely attaches to cable through crimping
  • Gold plated design
  • Works with both RG-6 and Quad Shield RG-6
091-1060
Weight: 0.027 lbs.
IN STOCK
List Price$2.99
You Save34%
$1.95
Buy 10-up$1.80
Part # 091-1060
The video RCA connector offers maximum versatility for the Audio/Video Contractor. With the capabilities of working with both RG-6U and RG6 quad shield cable along with an attached ferrule for quick terminations, this allows increased on-site work efficiency. This Crimp-on connector will save you time and money, never solder or use twist-on RCA connectors that might cost you a service call later. This unique design will allow one connector to crimp-on both RG-6U and RG6U quad shield coax cable. Perfect for home theater applications when using composite video. This gold plated connector is the fastest way of putting an RCA connector on a coax cable. To use, simply strip the coax using a rotary stripper and insert the center conductor into the center pin of the RCA connector. The center pin actually squeezes the center conductor of the cable insuring a reliable connection, then crimp the connector on. Perfect for out in the field where time is money. Crimp tool die size is .360".
Specifications: • Contact plating: gold • Sold per: each • Entry hole: 1.13" • Termination style: crimp • Entry hole: 9 mm • Dimensions: 0.40" x 1.13".
  • GenderMale / Plug
  • Mounting TypeCable Mount
  • BrandParts Express
  • Part Number091-1060
  • UPC844632014468
  • Product CategoryRCA Connectors
    (12 Reviews)
  • Weight0.027 lbs.
RCA RG-6 Quad Compression Connector
Part # 092-498
View similar products to the RCA Male Crimp-On Connector For RG-6/U & Quad
in the RCA Connectors product category.
RCA Male Crimp-On Connector For RG-6/U & Quad is rated 4.3333 out of 5 by 12.
Rated 4 out of 5 by from ImpressiveBeen waiting this type of connector for awhile. Have a few video applications I can't wait to use it on.
Date published: 2010-03-27
Rated 4 out of 5 by from Beefy.Order a couple of extras to practice if you're new to crimping RG6 cables. This part is not exactly user-friendly (hence 4 stars for features) for novice users, but learning curve is shallow if you are.Also, "bite the bullet" and buy a rotary cable stripper and a compression tool--you won't be sorry. You'll use them I use a compression/crimp tool and heat shrink tubing for a clean, solid, and professional job. You'll use both tools more than you would think.http://www.parts-express.com/pe/showdetl.cfm?Partn umber=360-016http://www.parts-express.com/pe/showdetl.cfm?Partn umber=360-046
Date published: 2009-11-16
Rated 4 out of 5 by from good quality connectorOnce you figure out the proper wire lengths and technique, the connectors work well and are secure.If you are going to use this connector, do some research online and understand how to properly use connectors like this. Buy a couple of extra to experiment with.
Date published: 2008-11-18
Rated 5 out of 5 by from Gets the job done wellI used this to terminate the end of a 33 foot RG6 subwoofer cable. I did not use a crimper - just wrapped a little black electrical tape around the outer jacket to give me a tighter fit. It works well! Nice stout connector.
Date published: 2008-11-16
Rated 4 out of 5 by from Solid, but bigThese are big, heavy, well-made plugs. However, this can work against them. If you are planning on using these to make connections behind your wall plates, you may run out of space when you consider the bend radius of cl-2 quad-shielded RG-6 cables and the length of these connectors.
Date published: 2008-08-29
Rated 5 out of 5 by from works great for subwoofer connectorsI used this WITHOUT a crimper and they worked well. I am careful about pulling on the wire- but in normal use - with extra care to grap the plug only when pulling out- I have had no problems even without crimping!
Date published: 2008-08-27
Customer projects that include: RCA Male Crimp-On Connector For RG-6/U & Quad
