090-280_ALT_0
RCA Chassis Jack Connector
Brand:|Part # 090-280
This RCA chassis jack is an economical choice for adding RCA jacks to project boxes or any other non-conductive surface!
$0.77
Buy 10-99 $0.71
Buy 100+$0.49
Part # 090-280
  • Attractive nickel plating
  • Low-profile allows for close spacing
This nickel-plated RCA jack is a good option for those looking to add RCA jacks to home-built amplifiers and is ideal for mounting on ABS project boxes
Please note: This RCA jack is not insulated and is only suited for mounting on plastic or other non-conductive surfaces.
Specifications: • Contact plating: nickel • Sold per: each • Connection style: solder • Dimensions: 0.88" x 0.63".
  • GenderFemale / Jack
  • Mounting TypeChassis / Panel Mount
  • BrandParts Express
  • Part Number090-280
  • UPC844632010132
  • Product CategoryRCA Connectors
    (4 Reviews)
  • Weight0.0066 lbs.
View similar products to the RCA Chassis Jack Connector
in the RCA Connectors product category.
RCA Chassis Jack Connector is rated 4.5 out of 5 by 4.
Rated 4 out of 5 by from Reasonable for the moneyBe careful soldering to the center conductor - too much heat/time and the plastic shell melts easily and makes a mess. For less than a dollar these are a great deal though.
Date published: 2014-11-26
Rated 5 out of 5 by from Great project addition.Perfect for adding audio/video inputs/outputs to a project or to repair a unit. Don't over tighten!!!! It doesn't tolerate it too well (it will snap).
Date published: 2013-07-01
Rated 4 out of 5 by from Does what its made to do.Good little rca jack, does exactly what its made to do.
Date published: 2009-09-24
Rated 5 out of 5 by from just what I neededThis panel mount jack was just the ticket for my rebuild of an old Dynaco tube amp. It fit right and performed as it should.
Date published: 2007-12-31
  • 2016-02-11T06:56CST
  • co_hasreviews, tv_0, tr_4
  • loc_en_US, sid_090-280, PRD, sort_mostRecent
scew in mout -what diameter
do these jacks screw into the chassis panel.What is the diameter of the hole to accommodate them
Asked by: bobdruk
It is not "screw-in" mount. It is thru-hole mount with a nut. 1/4" clearance hole required. These are great for sheet metal becus the ground is on the outside. Should not be used for speaker termination on 1-chip amps with floating outputs unless mounted in a plastic case.
Answered by: Fanden
Date published: 2012-02-06
  • 2016-02-11T07:30CST
  • loc_en_US, sid_090-280, PRD, sort_recentQuestionsFirst
