RCA ANT1450B Multi-Direction Amplified HDTV Antenna
Brand:|Model: ANT1450B|Part # 210-332
This indoor antenna will outperform your old traditional antenna, thanks to the 360 degree patented reception technology!
List Price$44.99
You Save40%
$26.90
Part # 210-332
  • Receives local HD, all digital TV broadcasts and FM radio signals
  • 360 degree reception
  • Enhances reception by amplifying weak signals
  • Supports all digital and analog TV frequencies via VHF and UHF
  • Supports HDTV 1080 broadcast
  • Patented technology eliminates constant adjustment
The RCA ANT1450B antenna eliminates the constant need for adjustment, and you will get the local channels you want. Just hang it, lay it flat, or stand it upright and receive local HD, DTV, and FM signals for free. The ultra low noise amplifier provides clear reception of HDTV, UHF, or VHF signals. Slim profile can be hung on a wall or lie flat, and an included metal easel stand allows vertical placement. Comes in a black finish to complement any home theater center and outperforms traditional antennas thanks to its patented design. Preserves signal purity with extremely low noise circuitry. Additional features: Simple connection to your TV or converter box, easy to hide in any room environment, removable amplifier included with antenna, coax cable included, one year limited warranty. Dimensions: 9" H x 8" W x 1/2" D
  • BrandRCA
  • ModelANT1450B
  • Part Number210-332
  • UPC044476061165
  • Product CategoryHDTV / TV Antennas
    (5 Reviews)
  • Weight2.32 lbs.
View similar products to the RCA ANT1450B Multi-Direction Amplified HDTV Antenna
in the HDTV / TV Antennas product category.
RCA ANT1450B Multi-Direction Amplified HDTV Antenna is rated 3.4 out of 5 by 5.
Rated 1 out of 5 by from No reception at allProduct package states 60 mile reception. I live within 25 miles of several stations and live at the top of a hill. Tried it inside the house and even moved it outside for a test. Tried connecting it to 2 different TV's. No reception at all. Returned it thinking it was obviously bad. The replacement unit did the same thing. No reception. The product description is extremely misleading. I would not recommend this product.
Date published: 2015-03-04
Rated 5 out of 5 by from Brings in tons more stations than my old antenna!I combined my old attic tv antenna (the long, ugly horizontal type with many rods all over the place) and used a splitter to run them through the amplifier section of this unit into my new digital 32 inch flat screen tv. I now get about 25 channels and they come in clearly most of the time. I live about 30 miles from NYC and get all the channels that we used to get before cable and a bunch of new ones.Before this we got about 5 channels. Great price. Place it as high as you can near the window or vent (inside attic)
Date published: 2014-11-07
Rated 5 out of 5 by from Great antennaPurchased this antenna to be able to get the free channels that are offered. GREAT antenna. Even pulled up some stations I did not know we could get free!!
Date published: 2014-10-02
Rated 1 out of 5 by from i got channel 28 (ch9 is what that is)thought id give this a try being im up on top of a hill but it didnt work for me i got 28-1 28-2 28-3 thats it no fm either . thought i could go away from cable but guess notoh well guess a waste of $ my loss .
Date published: 2014-03-23
Rated 5 out of 5 by from AntennaAwesome product. Works great. The HD reception is better than expected.
Date published: 2014-01-22
  • 2016-02-06T07:12CST
  • co_hasreviews, tv_0, tr_5
  • loc_en_US, sid_210-332, PRD, sort_mostRecent
The antenna is promoted as Amplified.  That generally means that it requires and external power source to power the amplifier.   Does it require an external power source?
Asked by: jimb123
It has a removable amplifier insert with built-In coaxial cable connections which does require power. But it does not require external power to work without the amplifier.
Answered by: GregT
Date published: 2015-05-21
To set up with t.v. it gives me the options cable and air which of the two do I choose?
Asked by: katie123
You will want to choose the "Air" option for use with an antenna.
Date published: 2014-11-04
Is the F connector Male or female ?
Asked by: johnnypotatoes
The F connector on this antenna is male.
Date published: 2014-05-20
Do you sell a tuner that will work with this?
Asked by: mistereight2u
Unfortunately we do not have a tuner that will work with this.
Date published: 2014-05-02
hi im trying to hook it up ? but I have a simpletv.com dvr and its hooked up to my cable box ! I have a tv tunner on the back of my tv ? can I plug my hdtv to it?
Asked by: markanthony
This plugs into the coax input on the back of the TV, it will connect to any TV that has a tuner built in.
Date published: 2014-02-21
  • 2016-02-06T08:43CST
  • co_hasquestionsanswers, tq_5
  • loc_en_US, sid_210-332, PRD, sort_recentQuestionsFirst
