RapidRun 42406 Digital Runner CL2 V1.3 65 ft.
Brand:|Model: 42406|Part # 183-824
RapidRun's 65 ft. high-speed, CL2-rated digital runner cable is the complete in-wall solution for digital multimedia applications.
  • Color Code: Red
  • Each connector includes a protective pulling cap that can withstand 30 pounds of pulling tension
  • Supports HDMI and DVI-D high resolution video up to 1080p (4.95 Gbps)
  • CL2-rated for in-wall installations
RapidRun® is designed to be the standard for in-wall audio/video installations. The RapidRun system empowers you to customize your installation to create your own ideal audio/video solution. Break-away flying leads and wall plates ensure flexible, efficient, high quality connections for all types of equipment. Use this 65 ft. digital runner for in-wall installations in homes when connecting an HDTV to different source devices, or for connecting a PC to a monitor or projector. Whether hanging a flat panel TV in a home or installing a commercial digital signage system, you can count on a crisp, clean signal up to 1080p resolution every time! When running a digital signal at this length with RapidRun, a passive flying lead or wall plate can be used on the source end, and an active flying lead or wall plate will be required on the display end. Terminate with flying leads (with lengths up to 10 feet), or with wall plates (available in three colors) to meet the specific requirements of your installation.
Please Note: Each complete RapidRun solution requires a passive break-away flying lead or passive wall plate on the source end, and an active break-away flying lead or active wall plate on the display end to terminate the runner cable. This version of RapidRun Digital will support the HDMI™ High Speed specification.
  • TypeRunner Cables
  • FormatDigital HDMI / DVI
  • BrandRapidRun
  • Model42406
  • Part Number183-824
  • UPC757120424062
  • Product CategoryRapidRun Modular Cable System
  • Weight6.61 lbs.
View similar products to the RapidRun 42406 Digital Runner CL2 V1.3 65 ft.
in the RapidRun Modular Cable System product category.
