RapidRun 42319 Aluminum Wall Plate HD15+3.5+3RCA+F
Brand:|Model: 42319|Part # 183-809
Use with a PC Runner (yellow) to connect a projector, and any display requiring an HD15, 3.5 mm audio, and audio/video connection; the f-81 coupler allows connection to antenna, cable or satellite TV service.
  • Color Code: Yellow (for use with PC Runners)
  • Supports transmission of RGBHV signals, 3.5mm stereo audio, and composite audio/video
  • RF pass-through for CATV/SATV
  • Fits into a standard single gang J-box
RapidRun® is designed to be the standard for in-wall audio/video installations. The RapidRun system empowers you to customize your installation to create your own ideal audio/video solution. Break-away flying leads and wall plates ensure flexible, efficient, high quality connections for all types of equipment. Ideal for educational and institutional installations. Use with a PC Runner (yellow) to connect a projector, and any display requiring an HD15, 3.5 mm audio, and audio/video connection; the f-81 coupler allows connection to antenna, cable or satellite TV service. Constructed from aluminum for durability, this wall plate has a locking connector that enables the integrator to save valuable space inside the surface mount or electrical box that typically is already packed with cables.
Please Note: Each complete RapidRun solution requires a break-away flying lead or wall plate to terminate each end of the runner cable. For each runner you will need (2) break-away flying leads, (2) wall plates, OR (1) break-away flying lead and (1) wall plate.
  • TypeWall Plates / Inserts
  • FormatMultimedia A/V
  • BrandRapidRun
  • Model42319
  • Part Number183-809
  • UPC757120423195
  • Product CategoryRapidRun Modular Cable System
  • Weight0.4 lbs.
View similar products to the RapidRun 42319 Aluminum Wall Plate HD15+3.5+3RCA+F
in the RapidRun Modular Cable System product category.
