RapidRun 42313 Aluminum Wall Plate HD15+3.5+3RCA White
Brand:|Part # 183-807
Use with a PC Runner (yellow) to connect a projector, and any display requiring an HD15, 3.5 mm audio, and audio/video connection.
  • Color Code: Yellow (for use with PC Runners)
  • Supports transmission of RGBHV signals, 3.5mm stereo audio, and RCA composite audio/video
  • Fits into a standard single gang J-box
RapidRun® is designed to be the standard for in-wall audio/video installations. The RapidRun system empowers you to customize your installation to create your own ideal audio/video solution. Break-away flying leads and wall plates ensure flexible, efficient, high quality connections for all types of equipment. Ideal for educational and institutional installations, commonly used at the teacher's station with the display (projector) end of classroom setups with the corresponding flying lead (#42323, #42327, #42328 or #42329). Use with a PC Runner (yellow) to connect a projector, and any display requiring an HD15, 3.5 mm audio, and audio/video connection. Constructed from aluminum for durability, this wall plate has a locking connector that enables the integrator to save valuable space inside the surface mount or electrical box that typically is already packed with cables.
Please Note: Each complete RapidRun solution requires a break-away flying lead or wall plate to terminate each end of the runner cable. For each runner you will need (2) break-away flying leads, (2) wall plates, OR (1) break-away flying lead and (1) wall plate.
  • TypeWall Plates / Inserts
  • FormatMultimedia A/V
  • BrandRapidRun
  • Part Number183-807
  • UPC757120423133
  • Product CategoryRapidRun Modular Cable System
  • Weight0.45 lbs.
View similar products to the RapidRun 42313 Aluminum Wall Plate HD15+3.5+3RCA White
in the RapidRun Modular Cable System product category.
