RapidRun 42312 Aluminum Wall Plate HD15+3.5+3RCA+4KS
Brand:|Model: 42312|Part # 183-806
Use with a PC Runner (yellow) to connect a projector, and any display requiring an HD15, 3.5 mm audio, and audio/video connection; the four keystone bezels enable network, USB, Telephone, RF and AV connectivity.
  • Color Code: Yellow (for use with one PC Runner) and Blue (for use with one Multimedia Runner)
  • Supports transmission of RGBHV signals, 3.5mm stereo audio, and RCA composite audio/video
  • Fits into a standard double gang J-box
RapidRun® is designed to be the standard for in-wall audio/video installations. The RapidRun system empowers you to customize your installation to create your own ideal audio/video solution. Break-away flying leads and wall plates ensure flexible, efficient, high quality connections for all types of equipment. Ideal for educational and institutional installations. Use with a PC Runner (yellow) to connect a projector, and any display requiring an HD15, 3.5 mm audio, and audio/video connection; the four keystone bezels enable network, USB, Telephone, RF and AV connectivity. Constructed from aluminum for durability, this wall plate has a locking connector that enables the integrator to save valuable space inside the surface mount or electrical box that typically is already packed with cables. The included keystones use any standard size keystone insert such as RJ45 for network connectivity or a pass-through USB insert for connecting to a printer or interactive whiteboard.
Please Note: Each complete RapidRun solution requires a break-away flying lead or wall plate to terminate each end of the runner cable. For each runner you will need (2) break-away flying leads, (2) wall plates, OR (1) break-away flying lead and (1) wall plate.
  • TypeWall Plates / Inserts
  • FormatMultimedia A/V
  • BrandRapidRun
  • Model42312
  • Part Number183-806
  • UPC757120423126
  • Product CategoryRapidRun Modular Cable System
  • Weight0.5 lbs.
View similar products to the RapidRun 42312 Aluminum Wall Plate HD15+3.5+3RCA+4KS
in the RapidRun Modular Cable System product category.
