RapidRun 42310 Aluminum Wall Plate (2)HD15+(2)3.5+3RCA+KS
Brand:|Model: 42310|Part # 183-804
Use with two PC Runners (yellow) to connect a projector, PC, and any display requiring an HD15, 3.5 mm audio, and audio/video connection; the keystone bezel enables network, USB, Telephone, RF or AV connectivity.
  • Color Code: Yellow (for use with PC Runners)
  • Supports transmission of RGBHV signals, 3.5mm stereo audio, and RCA composite audio/video
  • Fits into a standard double gang J-box
RapidRun® is designed to be the standard for in-wall audio/video installations. The RapidRun system empowers you to customize your installation to create your own ideal audio/video solution. Break-away flying leads and wall plates ensure flexible, efficient, high quality connections for all types of equipment. Ideal for educational and institutional installations. Use with two PC Runners (yellow) to connect a projector, PC, and any display requiring an HD15, 3.5 mm audio, and audio/video connection; the keystone bezel enables network, USB, Telephone, RF or AV connectivity. Constructed from aluminum for durability, this wall plate has a locking connector that enables the integrator to save valuable space inside the surface mount or electrical box that typically is already packed with cables. The included keystone uses any standard size keystone insert such as RJ45 for network connectivity or a pass-through USB insert for connecting to a printer or interactive whiteboard.
Please Note: Each complete RapidRun solution requires a break-away flying lead or wall plate to terminate each end of the runner cable. For each runner you will need (2) break-away flying leads, (2) wall plates, OR (1) break-away flying lead and (1) wall plate.
  • TypeWall Plates / Inserts
  • FormatMultimedia A/V
  • BrandRapidRun
  • Model42310
  • Part Number183-804
  • UPC757120423102
  • Product CategoryRapidRun Modular Cable System
  • Weight0.63 lbs.
View similar products to the RapidRun 42310 Aluminum Wall Plate (2)HD15+(2)3.5+3RCA+KS
in the RapidRun Modular Cable System product category.
