RapidRun 42135 Runner UXGA CL2 PC-Y 10 ft.
Brand:|Model: 42135|Part # 183-836
Color coded yellow, the 10 ft. PC runner is the high performance in-wall solution for PC-based applications; UXGA resolution is ideal for projector and large display presentations.
  • Color Code: Yellow
  • CL2-rated for in-wall installations
  • Each connector includes a protective pulling cap that can withstand 30 pounds of pulling tension
  • Supports resolutions up to 1600 x 1200 pixels (UXGA resolution)
RapidRun® is designed to be the standard for in-wall audio/video installations. The RapidRun system empowers you to customize your installation to create your own ideal audio/video solution. Break-away flying leads and wall plates ensure flexible, efficient, high quality connections for all types of equipment. Use this CL2-rated 10 ft. PC runner for in-wall installations that support computer-based applications. Whether hanging a projector in a modern 21st century classroom or installing a commercial digital signage system, a clean, crisp signal will be delivered every time. Terminate with flying leads (with lengths up to 10 feet), or with wall plates (available in three colors) to meet the specific requirements of your installation.
Please Note: Each complete RapidRun PC Runner solution requires a break-away flying lead or wall plate to terminate each end of the runner cable. For each runner you will need (2) break-away flying leads, (2) wall plates, OR (1) break-away flying lead and (1) wall plate.
  • TypeRunner Cables
  • FormatMulti-format Integrated
  • BrandRapidRun
  • Model42135
  • Part Number183-836
  • UPC757120421351
  • Product CategoryRapidRun Modular Cable System
  • Weight0.96 lbs.
View similar products to the RapidRun 42135 Runner UXGA CL2 PC-Y 10 ft.
in the RapidRun Modular Cable System product category.
