183-730_ALT_0
183-730_ALT_1
RapidRun 40854 HD15 + 3.5mm Audio White Wallplate
Brand:|Part # 183-730
Once you've selected the correct Runner for your job, you simply need to select the proper Break-Away termination. This wall plate terminates a Runner to an HD-15 female connector and a 3.5 mm stereo audio female jack.
  • Color-coded to match the compatible Runner, yellow to yellow
  • Decora™ compatible wall plate
  • Speeds up installation; saves time and money
  • Interchangeable leads for equipment upgrades or changes
  • Patented design ensures signal integrity over long runs
  • Run HD15 and 3.5 mm audio signals over one cable, 3.5 mm female connector
Once you've selected the correct Runner for your job, you simply need to select the proper Break-Away termination. There is no performance difference or installation penalty; choose the connection that is right for you! Mix and match-with Decora compatible wall plates and flying leads-there are no limitations with RapidRun! Break-Away terminations are finished with a male MUVI connector for an instant and effortless connection to the runner. Simply fit the connectors together (the connectors are keyed, so they can’t be incorrectly attached) and tighten the knurled locking rings. It's that simple! Break-Away configurations are available in your choice of a flying lead or Decora compatible wall plate. For example, you can easily have Break-Away flying leads in the equipment closet connected directly to a multi-zone receiver, and have the other end terminated in an attractive Break-Away wall plate in a remote zone. With RapidRun, you won't compromise looks for performance. Yellow banded wall plates are designed to work with yellow banded Runners. Blue banded wall plates are designed to work with blue banded Runners. Green banded wall plates are designed to work with both yellow and blue banded Runners. Sold individually, Runners and flying leads sold separately. Note: Each Runner requires a flying lead or wall plate on both ends for operation.
  • TypeFlying Leads
  • FormatPC / VGA
  • BrandRapidRun
  • Part Number183-730
  • UPC757120408543
  • Product CategoryRapidRun Modular Cable System
  • Weight0.23 lbs.
View similar products to the RapidRun 40854 HD15 + 3.5mm Audio White Wallplate
in the RapidRun Modular Cable System product category.
