Rapid Link Power Recessed Power Outlet Kit White
Brand:|Part # 261-175
Install a dual electrical outlet anywhere one is needed with the Rapid Link Power kit. Not only does it open up placement options, it's as easy to install as a low voltage device.
List Price$99.99
You Save31%
$69.00
Buy 4+$59.50
Part # 261-175
  • Install a dual power outlet where you need it
  • Easy and quick to use
  • National Electric Code compliant
  • Great for use with flat panel HDTVs, projectors, and powered subwoofers
Flat panel HDTVs, office and home theater projectors, and powered subwoofers suffer from a common problem. Each requires a power outlet. In the past this has limited placement options, calling up an electrician (adding hundreds of dollars to an installation), or using an unsightly extension cord…not any more. Install a dual electrical power outlet wherever needed with the Rapid Link Power kit. Not only does it open up possible placement options, it's as easy to install as a low voltage device. The Rapid Link Power kit works by transferring power from an existing outlet to where you need it. ROMEX® electrical wire (ROMEX not included) is used to connect the AC outlet receptacle (which is mounted to the desired power location) to the AC inlet receptacle (which is mounted within 36" of an existing outlet). A 36" electrical cord is included to provide power to the AC inlet receptacle. Both the AC inlet and AC outlet feature unique recessed connections to maximize mounting clearance. The included PVC electrical boxes feature dog-ear mounting tabs for retro-fit applications.
National Electric Code requirements are met with the Power Bridge so that you can be sure that it's safe. Rated at 125 VAC, 15A. Kit includes one recessed dual AC power outlet, one AC power inlet, 36" electrical extension cord, and two PVC electrical boxes.
Note: The Rapid Link Power kit is not designed to be wired directly to an electrical circuit. It is designed to connect to a grounded existing electrical outlet only.
  • BrandParts Express
  • Part Number261-175
  • UPC741835080439
  • Product CategoryPower Outlet / Box Kits, 110V
    (3 Reviews)
  • Weight1.6 lbs.
