262-859_ALT_0
262-859_ALT_1
Rack Panel 3RU with Two 115VAC Cooling Fans
Brand:|Part # 262-859
Each of the two 4-5/8" fans is rated for a maximum of 115 CFM air flow at 3100 RPM. The included snap-on air filters are easily cleaned using a mild detergent and warm water.
List Price$79.99
You Save45%
$43.89
Buy 4-49 $36.50
Buy 50+$32.50
Part # 262-859
  • Two pre-mounted fans deliver up to 115 CFM of air flow each
  • Snap-on air filters
  • Heavy-duty one-piece 0.065" steel construction
  • Black matte painted finish
  • Flanged edges for more structural support
Keep it cool with the 3RU rack fan panel. Each of the two 4-5/8" fans is rated for a maximum of 115 CFM air flow at 3100 RPM. The included snap-on air filters are easily cleaned using a mild detergent and warm water. The panel is made from 15 gauge perforated steel and painted to a matte black finish. Flanged edges reduce flexing.
Specifications: • Voltage: 115 VAC, 60 Hz, 240 mA • Fan power connections: 10" wire leads • Fans: 2 • Noise: Less than 49 dBA • Panel dimensions: 3RU; 5-1/4" H x 19" W.
Fans require 100 to 120 VAC electrical connection for use. Power plug required and sold separately.
  • Product TypeCooling Systems
  • BrandParts Express
  • Part Number262-859
  • UPC844632080807
  • Product CategoryEquipment Cooling
  • Weight4.2 lbs.
View similar products to the Rack Panel 3RU with Two 115VAC Cooling Fans
in the Equipment Cooling product category.
Do you have any kind of decibel estimate of these fans?
Asked by: Technician
Do the fans come with AC plugs?
Asked by: bwvideo14
No, it does not. It has two 10" leads for each fan.
Answered by: MattW
Date published: 2015-07-22
Can the fans be run in series for 208Vac operation?
Asked by: tyrebyter
not recommended.
Answered by: TomI
Date published: 2015-04-22
Are these fans designed to exhaust heat out of the cabinet or blow air into the cabinet or can they be reversed to go either way. The dimension listed is 51/4 high, 19 wide but what is the thickness, or how much space is required inside the cabinet
Asked by: revron123
These are installed so the air is drawn out from the rack, but they can be dismounted and flipped 180 degrees if you would rather reverse the air flow. The overall depth of this is 2", but I would recommend a minimum of at least 4" for proper air flow.
Date published: 2016-02-04
  • 2016-02-06T08:11CST
  • co_hasquestionsanswers, tq_4
  • loc_en_US, sid_262-859, PRD, sort_recentQuestionsFirst
