Quam SYSTEM 8/VC 8" Shallow Surface Mount Speaker 5W-25/70V
Brand:|Model: SYSTEM 8/VC|Part # 244-3064
The SYSTEM 8/VC by Quam is an 8" shallow surface mount black loudspeaker assembly with a 5 watt-25/70.7V pigtail transformer, and volume control.
Part # 244-3064
  • 8" O.D. full range loudspeaker
  • 5W-25/70.7V pigtail transformer
  • For indoor environments
  • Program material: Signal tones, voice, and music
  • Made in Chicago, USA
Quam's SYSTEM 8/VC is a complete loudspeaker assembly with an 8" O.D., full range loudspeaker, 5 watt-25/70.7V pigtail transformer, volume control, and 22 gauge steel enclosure. Wood baffle with cloth wrapped grill. Enclosure finish is a black baked epoxy hybrid. Intended use in an indoor environment surfaced mounted for signal tones, voice, and music. Made in Chicago, USA.
Specifications: • 25/70.7V transformer: 5, 2.5, 1.25, 0.63, 0.31 watt • Average sensitivity: 92 dB 1W/1m • Power rating: 12 watts RMS • Max system output: 99 dB SPL, 5W/1m • Magnet type, weight: BeFe ceramic, 4.8 oz. nominal • Frequency response: 65 Hz - 17 kHz • Nominal coverage angle: 90° included angle, -6 dB/ 2 kHz, half space • Audio connection: 7" color-coded pigtails, pre-cut.
  • Input Rating70V,25V
  • Woofer Diameter8"
  • ConfigurationFull-range
  • ColorBlack
  • BrandQuam
  • ModelSYSTEM 8/VC
  • Part Number244-3064
  • UPC844632097157
  • Weight5 lbs.
View similar products to the Quam SYSTEM 8/VC 8" Shallow Surface Mount Speaker 5W-25/70V
