Quam SYSTEM 3/VC 8" Slanted Speaker w/Volume Control 5W-25/70V White
Brand:|Model: SYSTEM 3/VC|Part # 244-3056
The SYSTEM 3/VC by Quam is a complete full range white loudspeaker assembly with an 8" O.D., 5 watt-25/70.7V transformer, and volume control.
List Price$68.49
You Save27%
$49.83
Buy 4+$43.90
Part # 244-3056
  • 8" O.D. full range speaker
  • 5W-25/70.7V pigtail transformer
  • For indoor environments
  • Program material: Signal tones, voice, and music
  • Made in Chicago, USA
Quam's SYSTEM 3/VC has a 5 watt-25/70.7V pigtail transformer, volume control, and 22 gauge steel baffle and slanted enclosure. Both the baffle and enclosure are finished in a white baked epoxy hybrid. Intended use in an indoor environment mounted on a vertical surface, downward firing for signal tones, voice, and music. Made in Chicago, USA.
Specifications: • 25/70.7V transformer: 5, 2.5, 1.25, 0.63, 0.31 watt • Average sensitivity: 92 dB 1W/1m • Power rating: 12 watts RMS • Max. system output: 99 dB SPL, 5W/1m • Magnet type, weight: BeFe ceramic, 4.8 oz. nominal • Frequency response: 65 Hz - 17 kHz • Nominal coverage angle: 100° included angle, -6 dB/ 2 kHz, half space • Audio connection: 7" color coded pigtails, pre-cut.
  • Input Rating70V,25V
  • Special FeaturesAngled
  • Woofer Diameter8"
  • ConfigurationFull-range
  • ColorWhite
  • BrandQuam
  • ModelSYSTEM 3/VC
  • Part Number244-3056
  • UPC844632096587
  • Weight5.75 lbs.
View similar products to the Quam SYSTEM 3/VC 8" Slanted Speaker w/Volume Control 5W-25/70V White
