CLEARANCE
244-3052_ALT_0
244-3052_ALT_1
244-3052_ALT_2
244-3052_ALT_3
Quam SYSTEM 2VP 8" Vandal-Proof Wall Mount Slanted Speaker 5W-25/70V White
Brand:|Model: SYSTEM 2VP|Part # 244-3052
The SYSTEM 2VP by Quam is an 8" vandal-proof wall mount slanted loudspeaker with a 5 watt-25/70.7V pigtail transformer.
List Price$115.05
You Save27%
$83.70
Buy 4+$73.75
Part # 244-3052
  • 8" O.D. full range speaker
  • 5W-25/70.7V pigtail transformer
  • For protected outdoor or indoor environments
  • Program material: Signal tones, voice, and music
  • Made in Chicago, USA
Quam's SYSTEM 2VP is a complete loudspeaker assembly with an 8" O.D., full range loudspeaker, 5W-25/70.7V pigtail transformer, 16 gauge square steel baffle and enclosure with a steel interwoven security screen mounted between the baffle and the loudspeaker. Finish is a white baked epoxy hybrid. Intended use in a protected outdoor or indoor environment, mounted on a vertical or horizontal surface for signal tones, voice, and music. Mounting hardware is #8-32 'pin-in-torx'.
Specifications: • 25/70.7V transformer: 5, 2.5, 1.25, 0.63, 0.31 watt • Average sensitivity: 97 dB 1W/1m • Power rating: 20 watts RMS • Max. system output: 104 dB SPL, 5W/1m • Magnet type, weight: BeFe ceramic, 10 oz. nominal • Frequency response: 80 Hz - 17 kHz • Nominal coverage angle: 100° included angle, -6 dB/ 2 kHz, half space • Audio connection: 7" color coded pigtails, pre-cut.
  • Input Rating70V,25V
  • Special FeaturesIndoor / Outdoor,Angled
  • Woofer Diameter8"
  • ConfigurationFull-range
  • ColorWhite
  • BrandQuam
  • ModelSYSTEM 2VP
  • Part Number244-3052
  • UPC844632097126
  • Weight11.6 lbs.
View similar products to the Quam SYSTEM 2VP 8" Vandal-Proof Wall Mount Slanted Speaker 5W-25/70V White
