Quam SYSTEM 20 24" x 24" Lay-In Ceiling Tile Speaker 20W-70V
Brand:|Model: SYSTEM 20|Part # 244-3178
Quam's SYSTEM 20 is a 24" x 24" lay-in ceiling speaker tile with a 6-1/2" O.D LF woofer, 1" O.D. HF tweeter, and 20 watt-70.7V rotary select transformer.
  • 24" x 24" lay-in speaker tile
  • 20W-70.7V rotary select transformer
  • For indoor environments
  • Program material: Signal tones, voice, and music
  • Made in Chicago, USA
The SYSTEM 20 by Quam is a complete 2-way loudspeaker assembly with an 6-1/2" O.D. LF woofer and 1" O.D. HF driver, 20 watt-70.7V, low loss, extended frequency response rotary select transformer, aluminum tread plate baffle, and integral molded fiber enclosure. Finish is a bright aluminum white baked epoxy hybrid over a raised tread plate pattern. Intended use in an indoor environment, mounted parallel to floor plane in a 24" wide suspended ceiling tile grid for music, voice, and signal tones. Made in Chicago, USA.
Specifications: • 70.7V transformer: 20, 10, 5, 2.5, 1.25 watt • Average sensitivity: 91 dB 1W/1m • Power rating: 30 watts RMS • Max. system output: 104 dB SPL, 20W/1m • Frequency response: 60 Hz - 20 kHz • Nominal coverage angle: 100° included angle, -6 dB/ 2 kHz, half space • Audio connection: 7" long, color coded tinned wires.
  • Input Rating70V
  • Mounting StyleDrop-in Tile
  • Special FeaturesEnclosed Back
  • Woofer Diameter6-1/2"
  • BrandQuam
  • ModelSYSTEM 20
  • Part Number244-3178
  • UPC844632097485
  • Product CategoryIn-Ceiling / On-Ceiling Speakers
  • Weight10 lbs.
View similar products to the Quam SYSTEM 20 24" x 24" Lay-In Ceiling Tile Speaker 20W-70V
in the In-Ceiling / On-Ceiling Speakers product category.
