Quam SYSTEM 12/8 24" x 24" Lay-In Ceiling Tile Speaker 8 Ohm
Brand:|Model: SYSTEM 12/8|Part # 244-3138
Quam's SYSTEM 12/8 is a 24" x 24" lay-in ceiling speaker tile 8" O.D with an 8 ohm nominal impedance.
OUT OF STOCK
Due In: 9/1/2016
List Price$81.90
You Save17%
$68.25
Buy 8+$65.00
Part # 244-3138
  • 24" x 24" lay-in speaker tile
  • 8 ohm nominal impedance
  • For indoor environments
  • Program material: Signal tones, voice, and music
  • Made in Chicago, USA
The SYSTEM 12/8 by Quam is a complete loudspeaker assembly with an 8" O.D., full range loudspeaker, perforated steel baffle, and integral molded fiber enclosure. Nominal impedance is 8 ohms. The SYSTEM 12/8 is UL Listed 1480- (UEAY, UAEY7-Canada) when installed in accordance with supplied installation instructions, requirements of NEC and AHJ. Intended use in an indoor environment, mounted parallel to floor plane in a 24" wide suspended ceiling tile grid for signal tones, voice, and music. Made in Chicago, USA.
Specifications: • Average sensitivity: 92 dB 1W/1m • Power rating: 12 watts RMS • Max. system output: 103 dB, 12W/1m • Magnet type: weight: BeFe ceramic, 4.8 oz. nominal • Frequency response: 65 Hz - 17 kHz • Nominal coverage angle: 100° included angle, -6 dB/ 2 kHz, half space • Audio connection: 7" long labeled, tinned wires, pre-cut.
  • Input Rating8 ohm
  • Mounting StyleDrop-in Tile
  • Special FeaturesEnclosed Back,UL1480
  • Woofer Diameter8"
  • BrandQuam
  • ModelSYSTEM 12/8
  • Part Number244-3138
  • UPC844632096792
  • Product CategoryIn-Ceiling / On-Ceiling Speakers
  • Weight7 lbs.
View similar products to the Quam SYSTEM 12/8 24" x 24" Lay-In Ceiling Tile Speaker 8 Ohm
in the In-Ceiling / On-Ceiling Speakers product category.
