Quam FM7Q2/70/G 6-1/2" Surface Mount Speaker 20W-70V Gray
Brand:|Model: FM7Q2/70/G|Part # 244-3028
Quam's FM7Q2/70/G is a complete surface mount gray framed loudspeaker assembly with a 6-1/2" O.D. low frequency woofer, 1" O.D. high frequency dome tweeter, and 70.7V transformer.
Part # 244-3028
  • 6-1/2" O.D. woofer and 1" dome tweeter
  • 20W-70.7V rotary select transformer
  • For protected outdoor and indoor environments
  • Program material: Signal tones, voice, and music
  • Made in Chicago, USA
The QUAM FM7Q2/70/G by Quam features a 6-1/2" O.D. LF driver, 1" O.D. HF tweeter, 20W-70.7V low loss, extended frequency response rotary select transformer with 8-ohm position. Has a steel 'MicroPerf' grille and steel frame. Loudspeaker is black with a gray frame and grill. Intended use for protected outdoor or indoor environments, surface mount, horizontal, or vertical installs for signal tones, voice, and music. Made in Chicago, USA.
Specifications: • 70.7V transformer: 20, 10, 5, 2.5, 1.25 watt • Average sensitivity: 91 dB, 1W/1m • Power rating: 30 watts RMS • 8 ohm tap output: 91 dB SPL, 1W/1m • Max. system output: 103 dB SPL, 20W/1m, 70.7V mode • Frequency response: 60 Hz - 20 kHz • Nominal coverage angle: 90° included angle, -6 dB/ 2 kHz, half space • Audio connection: Binding screw.
  • Input Rating8 ohm,70V
  • Special FeaturesIndoor / Outdoor
  • Woofer Diameter6-1/2"
  • Configuration2-way
  • ColorGray
  • BrandQuam
  • ModelFM7Q2/70/G
  • Part Number244-3028
  • UPC844632097065
  • Weight14 lbs.
View similar products to the Quam FM7Q2/70/G 6-1/2" Surface Mount Speaker 20W-70V Gray
