Clearance Item
Quam FM7Q1/8/W 6-1/2" Bracket Mount Speaker 8-ohm 30W White
Brand:| Model: FM7Q1/8/W
The FM7Q1/8/W by Quam is an all white 2-way loudspeaker that can handle up to 30 watts power with a 6-1/2" woofer and 1" dome tweeter.
  • 6-1/2" O.D. woofer and 1" dome tweeter
  • For protected outdoor or indoor environments
  • Program material: Signal tone, voice, and music
  • Made in Chicago, USA
244-3002
Weight: 13 lbs.
Quam's FM7Q1/8/W is a complete loudspeaker assembly with an 6-1/2" O.D. LF and 1" O.D. HF, steel 'MicroPerf' grille, steel frame and multiple position "U" bracket. Intended use is in a protected outdoor or indoor environment, surface mounted either horizontal or vertical for signal tones, voice, and music.
Specifications: • Average sensitivity: 91 dB SPL, 1W/1m • Power rating: 30 watts RMS • Max system output: 104 dB SPL, 30 watts/1m • Nominal impedance: 8 ohms • Frequency response: 60 Hz - 20 kHz • Nominal coverage angle: 90° included angle, -6 dB/ 2 kHz, half space • Audio connection: Binding screw.
  • Input Rating8 ohm
  • Special FeaturesIndoor / Outdoor
  • Woofer Diameter6-1/2"
  • Configuration2-way
  • ColorWhite
  • BrandQuam
  • ModelFM7Q1/8/W
  • Part Number244-3002
  • UPC844632096976
  • Product CategoryMulti-purpose On-wall Speakers
  • Weight13 lbs.
View similar products to the Quam FM7Q1/8/W 6-1/2" Bracket Mount Speaker 8-ohm 30W White
in the Multi-purpose On-wall Speakers product category.
Customer projects that include: Quam FM7Q1/8/W 6-1/2" Bracket Mount Speaker 8-ohm 30W White
