Quam FM7Q1/70/B 6-1/2" Bracket Mount Speaker 20W-70V Black
Brand:|Model: FM7Q1/70/B|Part # 244-3006
Quam's FM7Q1/70/B is a complete 2-way all black loudspeaker assembly with a 6-1/2" O.D. low frequency woofer, 1" O.D. high frequency tweeter, and 70.7V transformer.
Part # 244-3006
  • 6-1/2" O.D. woofer and 1" dome tweeter
  • 20W-70.7V rotary select transformer
  • For protected outdoor and indoor environments
  • Program material: Signal tones, voice, and music
  • Made in Chicago, USA
The FM7Q1/70/B by Quam features a 20W-70.7V low loss extended frequency response rotary select transformer with 8 ohm position. Has a steel 'MicroPerf' grill, steel frame and multiple position "U" bracket. Intended use for protected outdoor or indoor environments, surface mount, horizontal, or vertical installs for signal tones, voice and music. Made in Chicago, USA.
Specifications: • 70.7V transformer: 20, 10, 5, 2.5, 1.25 watt or 8 ohm • Average sensitivity: 91 dB 1W/1m • Power rating: 30 watts RMS • 8 ohm Tap output: 91 dB • Max. system output: 103 dB SPL, 20W/1m, 70.7V mode • Frequency response: 60 Hz - 20 kHz • Nominal coverage angle: 90° included angle, -6 dB/ 2 kHz, half space • Audio connection: Binding screw.
  • Input Rating8 ohm,70V
  • Special FeaturesIndoor / Outdoor
  • Woofer Diameter6-1/2"
  • Configuration2-way
  • ColorBlack
  • BrandQuam
  • ModelFM7Q1/70/B
  • Part Number244-3006
  • UPC844632096471
  • Weight11 lbs.
View similar products to the Quam FM7Q1/70/B 6-1/2" Bracket Mount Speaker 20W-70V Black
