245-642_ALT_0
QSC PLX3602 Power Amplifier
Brand:| Model: PLX3602
Product Video
PLX3602 Specifications: • Power output (stereo mode): 775 watts RMS x 2 (8 ohms), 1,250 watts RMS x 2 (4 ohms), 1,800 watts RMS x 2 (2 ohms) • Power output (bridge mono): 2,600 watts RMS x 1 (8 ohms), 3,600 watts RMS x 1 (4 ohms).
QSC Amplifier Rebate Offer at Parts Express
  • Patented PowerLight power supply technology with other patents pending
  • Very light weight - only 21 lbs.
  • Cooling design exhausts hot air out the front, keeping the rack cool
  • Front panel LED power, clip, -10 dB, and signal present indicators for system monitoring
  • Speakon® NL4 and binding post output connectors
  • 21-position front-panel gain controls for precise, repeatable amplifier adjustment
  • Balanced XLR inputs with parallel TRS connectors accommodate all common input connectors
245-642
Weight: 26 lbs.
IN STOCK
List Price$1,579.99
You Save20%
$1,259.99
Part # 245-642
The PLX2 series is a range of premium quality, high-power amplifiers designed for the most demanding live performance uses. Built on the third generation of QSC PowerLight® technology, PLX2 amplifiers combine light weight, superlative audio quality, and proven QSC reliability. With power ratings up to 3,600 watts, PLX2 amplifiers are capable of providing plenty of clean, undistorted output to the most power hungry speaker systems. Three-year manufacturer's warranty.
Two ways to get PLX2 performance:
The "02" model is the right choice for users who need to drive up to four loudspeakers from each amplifier channel (2 ohm loading), or when extremely high power bridge mono operation is required. These models feature built-in subwoofer processing, filter switches, and front panel indications of bridge mono status.
Mechanical
PLX2 series amplifiers have the refined, rugged good looks usually associated with high performance racing cars, competition bikes, professional power tools, and high power machinery. A solid, cast-aluminum front panel adds professional style to any rack while also acting as an integral I-beam, rigidly tying the chassis together for years of on-the-road reliability.
Additional mechanical touches such as the side stiffening rails, rear rack ears and cable tie anchor points attest to QSC's years of experience and attention to detail. QSC has even designed the integrated front handles so the amplifier slides into a rack without scraping the installers fingers on the rack sides. The exterior appearance of PLX2 amplifiers conveys what's inside - simply and truly, 13 to 21 pounds of the most advanced professional power amp on the planet.
PowerLight Technology
PowerLight switch mode technology replaces a large, heavy AC transformer (typically 20 lbs. / 9 kg) with a highly efficient and lighter-weight active design. Conventional AC transformers provide 100 or 120 energy pulses per second; the PowerLight supply delivers 190,000 to 230,000 pulses per second. More pulses make it easier to provide on-demand power for the amplifier's output section. The power supply doesn't "sag" so bass notes stay full and powerful while the high end remains crisp and clean.
Audio Quality
PLX2 audio power circuitry achieves performance normally associated with studio reference amplifiers. In order to reduce crossover distortion, precision bias tracking makes minute adjustments as amplifier temperature changes. The benefit is cleaner high-frequency and more consistent sound no matter how hard the amplifier is driven. The higher power models use QSC-exclusive class H output circuitry, a form of audio "turbocharging" that increases maximum power without affecting the basic audio quality.
Specifications: • Power output (stereo mode): 775 watts RMS x 2 (8 ohms), 1,250 watts RMS x 2 (4 ohms), 1,800 watts RMS x 2 (2 ohms) • Power output (bridge mono): 2,600 watts RMS x 1 (8 ohms), 3,600 watts RMS x 1 (4 ohms) • S/N ratio (20 Hz - 20 kHz): -107 dB • Input sensitivity: 1.25 Vrms • Voltage gain (at 8 ohms): 36 dB • Output circuitry: 2-tier Class H • Power requirement: 11.5A/120V • Distortion (SMPTE-IM): <0.02% • Distortion (typical): <0.02% (1/8" rated power, 20 Hz-20 kHz), <0.02% (Full rated power, 20 Hz-20 kHz) • Damping factor: >500 • Input impedance: 10k ohms unbalanced/20k ohms balanced • Dimensions: 3.5" (2 RU) H x 19" W x 12.8" (rack mounted), 14.875" (overall) D (8.9 x 48.3 x 32.6, 37.9 cm) • Weight: 21 lbs. (9.5 kg).
  • Power Output (RMS Per Channel @ 8 ohms)775 Watts
  • Output Channels2
  • Weight Range20 to 29 lbs.
  • BrandQSC Audio
  • ModelPLX3602
  • Part Number245-642
  • UPC684284050915
  • Product CategoryAmplifiers - Live Sound
    (3 Reviews)
  • Weight26 lbs.
View similar products to the QSC PLX3602 Power Amplifier
in the Amplifiers - Live Sound product category.
QSC PLX3602 Power Amplifier is rated 4.6667 out of 5 by 3.
Rated 4 out of 5 by from High end sound with QSC reliabilityOne of the best pro-audio amps I've ever owned! The sound comes really close to a hafler with the current reserves of a crown macrotech. Very clean, tight sound at all volume levels. This thing will spit out such tight low end and still give you delicate top end at the same time! On board adjustments are a little skimpy in versatility. S/N ratio is amazing - hands down the best sounding and most reliable amp you can buy for under 5000 bucks!
Date published: 2013-11-19
Rated 5 out of 5 by from My System RocksI connect three of these for highs, mids and lows and get a powerful clean sounding system. I have done several shows with these amps connected to JBL SRX series speakers and the system is awesome!
Rated 5 out of 5 by from best for the moneyVERY POWERFUL AMP, VERY LIGHTWEIGHT, I HIGHLY RECOMMEND THIS. THIS IS CHEAPER THAN YOUR CHIROPROCTOR.
Date published: 2013-11-05
Videos
Customer projects that include: QSC PLX3602 Power Amplifier
Part # 245-642
