QSC PLX1802 Power Amplifier
Brand:|Model: PLX1802|Part # 245-636
QSC's lightweight, reliable, and powerful PLX2 Series "02" amps feature 2 ohms/channel operation, flexible onboard customization options, and a third-generation PowerLight power supply.
ORDER TODAY
Ships in 7-10 Business Days
List Price$1,119.99
You Save20%
$899.99
Part # 245-636
  • Patented PowerLight power supply technology with other patents pending
  • Very light weight - only 21 lbs.
  • Cooling design exhausts hot air out the front, keeping the rack cool
  • Front panel LED power, clip, -10 dB, and signal present indicators for system monitoring
  • Speakon® NL4 and binding post output connectors
  • 21-position front-panel gain controls for precise, repeatable amplifier adjustment
  • Balanced XLR inputs with parallel TRS connectors accommodate all common input connectors
The PLX2 series is a range of premium quality, high-power amplifiers designed for the most demanding live performance uses. Built on the third generation of QSC PowerLight® technology, PLX2 amplifiers combine light weight, superlative audio quality, and proven QSC reliability. With power ratings up to 3,600 watts, PLX2 amplifiers are capable of providing plenty of clean, undistorted output to the most power hungry speaker systems. Three-year manufacturer's warranty.
Two ways to get PLX2 performance:
The "02" model is the right choice for users who need to drive up to four loudspeakers from each amplifier channel (2 ohm loading), or when extremely high power bridge mono operation is required. These models feature built-in subwoofer processing, filter switches, and front panel indications of bridge mono status.
Mechanical
PLX2 series amplifiers have the refined, rugged good looks usually associated with high performance racing cars, competition bikes, professional power tools, and high power machinery. A solid, cast-aluminum front panel adds professional style to any rack while also acting as an integral I-beam, rigidly tying the chassis together for years of on-the-road reliability.
Additional mechanical touches such as the side stiffening rails, rear rack ears and cable tie anchor points attest to QSC's years of experience and attention to detail. QSC has even designed the integrated front handles so the amplifier slides into a rack without scraping the installers fingers on the rack sides. The exterior appearance of PLX2 amplifiers conveys what's inside - simply and truly, 13 to 21 pounds of the most advanced professional power amp on the planet.
PowerLight Technology
PowerLight switch mode technology replaces a large, heavy AC transformer (typically 20 lbs. / 9 kg) with a highly efficient and lighter-weight active design. Conventional AC transformers provide 100 or 120 energy pulses per second; the PowerLight supply delivers 190,000 to 230,000 pulses per second. More pulses make it easier to provide on-demand power for the amplifier's output section. The power supply doesn't "sag" so bass notes stay full and powerful while the high end remains crisp and clean.
Audio Quality
PLX2 audio power circuitry achieves performance normally associated with studio reference amplifiers. In order to reduce crossover distortion, precision bias tracking makes minute adjustments as amplifier temperature changes. The benefit is cleaner high-frequency and more consistent sound no matter how hard the amplifier is driven. The higher power models use QSC-exclusive class H output circuitry, a form of audio "turbocharging" that increases maximum power without affecting the basic audio quality.
Specifications: • Power output, stereo mode (EIA 1 kHz, both channels driven): 330 watts RMS x 2 (8 ohms), 575 watts RMS x 2 (4 ohms), 900 watts RMS x 2 (2 ohms) • Power output, bridged mono mode (EIA 1 kHz): 1,200 watts RMS x 1 (8 ohms), 1,800 watts RMS x 1 (4 ohms) • Distortion (typical): <0.02% (1/8 rated power, 20 Hz-20 kHz), <0.02% (Full rated power, 20 Hz-20 kHz) • S/N ratio (20 Hz - 20 kHz): -107 dB • Input sensitivity: 1.28V • Input impedance: 10k ohms unbalanced/20k ohms balanced • Voltage gain (at 8 ohms): 32 dB • Damping factor: >500 • Output circuitry: Class AB • Dimensions: 3.5" (2RU) H x 19" W x 12.8" (rack mounted), 14.875" (overall) D • Weight: 21 lbs.
Parts Express is authorized to ship QSC products only within the United States, and will only ship QSC products to addresses located within the USA.
  • Power Output (RMS Per Channel @ 8 ohms)330 Watts
  • Output Channels2
  • Weight Range20 to 29 lbs.
  • BrandQSC Audio
  • ModelPLX1802
  • Part Number245-636
  • UPC684284050885
  • Weight26 lbs.
Pyle PPA200 Power Amplifier
Part #  248-4036
Peavey IPR2 5000 DSP Power Amplifier
Part #  248-7989
Peavey IPR2 7500 DSP Power Amplifier
Part #  248-7991
View similar products to the QSC PLX1802 Power Amplifier
Videos
Part # 245-636
