245-606_ALT_0
245-606_ALT_1
245-606_ALT_2
245-606_ALT_3
245-606_ALT_4
245-606_ALT_5
QSC KSub K Series Dual 12" Subwoofer System 1000W Class D
Brand:| Model: KSUB
The KSub is a dual-12" bandpass design, constructed of premium birch and includes high-quality, low-noise casters. This subwoofer features a threaded pole receptacle for a positive, wobble free connection to a threaded speaker pole (included).
QSC Free Tote Offer at Parts Express
  • Lightweight portable powered speakers with legendary QSC amplifier power and reliability
  • 1,000 watt Class D power module
  • Extensive DSP enhances system performance
  • Attractive and professional appearance
  • Tour-grade 18 gauge steel grill
  • Ergonomic handles with comfortable, non-slip grip
245-606
Weight: 91.85 lbs.
IN STOCK
Order Soon - Only 1 Left In Stock
List Price$1,369.99
You Save17%
$1,129.99
Part # 245-606
The QSC K Series is quite simply the new standard in lightweight powered loudspeaker systems. Under the direction of Pat Quilter, QSC's team of amplifier engineers have created a new standard in Class D power modules unparalleled in the industry. The KSub is a dual-12" bandpass design, constructed of premium birch and includes high-quality, low-noise casters. This subwoofer features a threaded pole receptacle for a positive, wobble free connection to a threaded speaker pole (included). Extensive DSP processing is employed throughout, providing levels of sonic clarity and total output that defy the system's size and weight.
Premium-grade materials, advanced construction processes and multiple mounting and suspension options allow for a wide range of live and installed applications. Remote gain control capability is offered via a potentiometer (not included) connected to the on-board Euroblock connector. In an installed application, multiple K Series speakers can be "daisy-chained" for total gain control from a single remote pot. Auto-standby mode is engaged after 5 minutes of inactivity.
Specifications: • Configuration: 4th order bandpass • Transducers: Low-frequency 2 x 12" cone transducers • Frequency response (-6 dB): 48 Hz - 134 Hz • Frequency range (-10 dB): 44 Hz - 148 Hz • Maximum SPL (1 m): 130 dB peak • Dimensions (including casters): 26" H x 14" W x 28.1" H (665 x 356 x 714 mm) • Weight: 74 lbs. (33.6 kg).
  • Speaker TypeActive / Powered
  • ConfigurationSubwoofer
  • Woofer Size12"
  • BrandQSC Audio
  • ModelKSUB
  • Part Number245-606
  • UPC684284055323
    (1 Reviews)
  • Weight91.85 lbs.
QSC KSub Padded Cover
Part # 245-616
View similar products to the QSC KSub K Series Dual 12" Subwoofer System 1000W Class D
QSC KSub K Series Dual 12" Subwoofer System 1000W Class D is rated 5.0 out of 5 by 1.
Rated 5 out of 5 by from most convenient, easiest to move, honest specsBesides the legendary reliability and sound-quality of QSC products, I particularly like the fact that they do not lie about power-ratings, frequency response or other specifications. That's especially important when choosing a subwoofer since practically ALL other manufacturers inflate their ratings to impress the gullible consumer.For any performer who carries his own equipment, ergonomics is also a crucial consideration. That where this particular subwoofer (and the whole K-series by QSC) has everyone else scrambling to catch up.The elegantly simple yet clever solution QSC provides here is including WHEELS on the BACK of this unit. Handles are on the top and bottom. That means when you move it, it rolls on its back and the handles are accessible for easy load in and out. The dual speaker design pushes massive volumes of air while allowing this to easily pass through narrow doorways. The casters are large. smooth and do not mar club-owners' expensive floors (or yours!)In the vertical position, a single pole pops in securely and fast! That is easier, faster, cheaper, more-stable and SAFER than folding / unfolding tripod-stands. No more pinched fingers! I can't even guess how many times I've moved equipment in four decades of professional playing, but I can say... this is sub is BY FAR the EASIEST to move and set up of any I have ever used.It sounds awesome and is a great value when you consider that you get superb B&C drivers and a top-quality QSC amp inside a beautifully engineered STURDY cabinet. Even if you have the engineering know-how and a shop full of woodworking equipment, you would be hard-pressed to make its equal for less money. Actually, I DO have a shop full of woodworking equipment AND a fair amount of experience designing and building speakers, but I still prefer just buying this sub.It would be difficult to get more acoustic-power in a smaller package at any price. At this price, it is a bargain.If you are considering up-grading your system or need a sub for any DJ, band use, you really must consider your time and effort in transporting and set-up. Add to that all the other quality features and immense acoustic output this model provides in such a tidy package, you will probably come to the same conclusion so many others have. This is the best sub for bands and DJs.
Date published: 2014-03-14
Customer projects that include: QSC KSub K Series Dual 12" Subwoofer System 1000W Class D
