QSC ISA 300Ti 70V Dual Channel Amplifier
Brand:|Model: ISA 300TI|Part # 245-696
The QSC ISA 300Ti power amplifier delivers clean, reliable output into the user's choice of low impedance or constant voltage speaker systems, or both load options simultaneously!
- Order Soon - Only 3 Left In Stock
$789.99
Part # 245-696
  • 25-, 70-, 100 volt, and low impedance outputs available simultaneously
  • Simple barrier strip connection determines output mode
  • DataPort V2 for use with DPV2-compatible signal processing accessories
  • Independent defeatable clip limiters for reduced distortion
  • Selectable 30 Hz or 70 Hz high-pass filters protect
  • Covered barrier strip output connectors for safety agency compliance
  • Stereo, Bridge, or Parallel operating modes
Designed as a cost-effective solution specifically for sound contractors, the "Ti" versions with isolated 25, 70 and 100 volt outputs for distributed audio systems. Versatile loading options and a comprehensive feature set make the ISA Series a rugged, cost-effective power solution for any permanently installed sound system.
Unique among distributed sound power amplifiers, the "Ti" versions will drive 8 or 4 ohm loads and a distributed system on the same channel simultaneously. This enables a contractor to reduce the number of required amplifier channels by allowing a limited number of distributed speakers to be attached to the same amp as is powering the main sound system.
Housed in a rugged 3-U chassis, the QSC ISA 300Ti features rear panel gain controls for tamper resistant operation, with 2 dB detents for quick and repeatable settings. Inputs include both XLR and detachable Euro-style connectors. Outputs feature covered barrier strip connectors for safety agency compliance, and for added versatility, a DataPort V2 (Version 2) terminated with an HD-15 connector is provided for use with DPV2-compatible signal processing accessories such as the XC-3 Crossover, SF-3 Subwoofer Filter, LF-3 Low Frequency Filter and the DSP-3 with external power supply.
Selectable high-pass filters are included to protect speakers and prevent speaker transformer saturation with minimal effect on program material. The ISA Series amplifiers provide additional protection circuitry including DC, infrasonic, thermal overload, RF and short circuit protection.
Specifications: • Power output, stereo mode (EIA 1 kHz, both channels driven): 185 watts x 2 (8 ohms); 280 watts x 2 (4 ohms); 430 watts x 2 (2 ohms) • Power output, XF output power, stereo mode: 300 watts x 2 (70V), 200 watts x 2 (25V) • Power output, bridged mono mode (EIA 1 kHz): 600 watts x 1 (8 ohms), 830 watts x 1 (4 ohms) • Distortion (typical): <0.01% • S/N ratio (20 Hz - 20 kHz, 8 ohms): 100 dB • Frequency response: Direct output, -3 dB @ 50 Hz. and -0.5 dB @ 20 kHz; XF output, 50 Hz - 16 kHz, +1 and -3 dB • Input sensitivity @ 8 ohms: 1.15V • Voltage gain @ 8 ohms: 33.4x (30.5 dB) • Output circuitry: Class AB • Dimensions: 5.25" (3RU) H x 19" W x 15.9" D • Weight: 44 lbs.
Parts Express is authorized to ship QSC products only within the United States, and will only ship QSC products to addresses located within the USA.
  • Power Output (RMS @ 70V)201W to 400W
  • Weight Range50 to 59 lbs.
  • BrandQSC Audio
  • ModelISA 300TI
  • Part Number245-696
  • UPC684284044990
  • Product CategoryCommercial Contractor Power Amplifiers
  • Weight50 lbs.
View similar products to the QSC ISA 300Ti 70V Dual Channel Amplifier
in the Commercial Contractor Power Amplifiers product category.
