QSC GX3 Power Amplifier 300 Watts/ch at 8 ohms
Brand:|Model: GX3|Part # 245-650
The GX3 power amplifier by QSC is ideal for 8 ohm speakers with a 250-350 watt power rating (program) or 4 ohm speakers with a 350-500 watt power rating (program).
List Price$399.99
You Save25%
$299.99
Part # 245-650
  • Power levels matched to the most popular speakers used by entertainers
  • Optimized for maximum real-world headroom into 4 ohm and 8 ohm speaker systems
  • Inputs: XLR, 1/4" TRS, and phono input connectors for compatibility with any source
  • Speakon® combo accepts, 1/4" (TS) plugs or Speakon 2 and 4-pole plugs for connection versatility
  • Built-in Subwoofer/Satellite crossover
  • GuardRail™ automatically protects the amplifier and loudspeakers from damage
  • Minimum depth chassis (10.1") fits in compact effects racks
QSC designers, headed by Pat Quilter, have optimized output and appearance while reducing raw material cost and weight. GX Series amplifiers are ideal for professional entertainers who require maximum performance and portability on a limited budget. It's all here – dramatic styling, easy hookup and adjustments, excellent audio quality and QSC reliability.
The hallmarks of the QSC brand - professional audio quality, meticulous engineering, precision manufacturing and long-term reliability - are all intrinsic to GX. Add contemporary styling, multiple input/output options, light weight, and advanced protection circuitry, and the GX Series clearly represents real value - something everyone can use.
GX amplifiers deliver just the right amount of power to the most popular speakers used by entertainers. Typically, loudspeaker manufacturers recommend an amplifier with power output equal to the speaker's Program (Music) Power rating or two times (2 x) the Continuous (RMS) Power rating.
Technical Notes
The GX3 uses the latest evolution of the QSC Grounded Collector output system, for optimum cooling of the critical power transistors. A true Class B biasing system combines maximum thermal efficiency with excellent audio performance.
This amplifier uses premium toroidal power transformers for reliable "mid-weight" performance. A variable-speed fan moves air crosswise through the amplifier, drawing cool air in over the power transformer, through the fan, and then over the heat sink. This keeps the transformer cool and allows a full size heat sink to fit in a down-sized chassis.
As always, GX Series amplifiers are fully protected from the usual hazards of the trade, ensuring stable performance and long life.
GuardRail™
GuardRail protection delivers full peak power while preventing detrimental overloads. During excessive clipping, or extreme overheating, GuardRail reduces gain just enough to preserve the integrity of the music, protect the speakers and keep the audience excited, without unprofessional distortion levels or shutdowns.
Subwoofer/Satellite Crossover
A subwoofer reduces strain on the full-range speaker, allowing it to play louder, or letting a smaller speaker do the same job. The GX Series supports this mode with a Crossover switch that splits the full-range input entering Ch 1, sending 20 Hz -100 Hz to the sub (Ch 1) and 100 Hz - 20 kHz to the top box (Ch 2). The front panel gain controls balance the sub and top box, while GuardRail optimizes peak power into the sub and top individually, for greater musical impact and dynamic range. GuardRail optimizes peak power into the sub and top individually, for greater musical impact and dynamic range.
Specifications: • Power output (EIA 1 kHz, both channels driven): 300 watts RMS x 2 (8 ohms), 425 watts RMS x 2 (4 ohms) • Distortion (typical): <0.02% 8 ohms, <0.05% 4 ohms • S/N ratio: 100 dB • Frequency response: 20 Hz - 20 kHz, +0 dB, -1 dB • Input sensitivity: 1.2V • Input impedance: >20k balanced • Voltage gain: 32.2 dB • Output circuitry: Class B • Dimensions: 3.5" (2RU) H x 19" W x 10.1" D • Weight: 27 lbs.
  • Power Output (RMS Per Channel @ 8 ohms)300 Watts
  • Output Channels2
  • Weight Range30 to 39 lbs.
  • BrandQSC Audio
  • ModelGX3
  • Part Number245-650
  • UPC684284055187
    (14 Reviews)
  • Weight30 lbs.
View similar products to the QSC GX3 Power Amplifier 300 Watts/ch at 8 ohms
